Old 07-29-2011, 12:05 PM
mdbasser mdbasser is offline
mdbasser is on a distinguished road
Default Fuel issues still
Could the PCM cause the fuse relay to have low or no voltage. If so how do I check this? Replaced transmission, when I went to start truck it would not start. Check fuel pump it is good. Replaced relays and fuses. Started tracing wires for breaks and found none. The relay seems to transfer only 4.5 volts to the fuel pump. I will get some fuel build up on the pressure check on the fuel rail but not much pressure. At my wits end as to why the pump will not run.
Old 07-29-2011, 06:49 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
A few suggestions - hit the "User CP" and complete your profile so we can see what your truck is, what engine you have, etc.
Tell us more about the truck so we can help.
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 04:16 PM
Fuel Fill Nozzle Shuts Off RamTech Dodge Ram Knowledge Base 3 11-22-2013 09:22 PM
SS/T Problems round 2 98sst Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 48 01-11-2010 07:54 PM
Fuel fill problems RamTech Dodge Ram Knowledge Base 3 01-09-2010 10:38 AM
dtc po148 nachizzle Cummins Diesel Specific Topics 2 06-09-2009 12:36 PM
