Old 07-29-2011, 02:03 PM
aoverland aoverland is offline
Vehicle: 2010 Ram 2500
aoverland is on a distinguished road
Default trailer lights trouble
Hooked up my boat for the first time and noticed that the brake lights work but nothing else. Fuses look good, I don't know much electrical. The trailer lights work fine on my other truck. Any ideas? Could there be another fuse elsewhere not under the hood?
Old 07-29-2011, 02:33 PM
moparornocar72's Avatar
Rep:630
not trying to be a smart A$$ but did you check the wiring to your turn signals and grounds on the trailer?
14.268 @ 95 MPH Full Trim
Old 07-29-2011, 02:54 PM
rainhater1 rainhater1 is offline
Vehicle: 2010 ram 1500 4x4 06 300 srt8
Trim Level: slt - big horn
Color: light graystone
Rep:116
rainhater1 will become famous soon enoughrainhater1 will become famous soon enough
There are a lot of non standard hookup's, the trailer was wired to the old truck, You need to change the trailer wiring to the truck which is correct.
Old 07-29-2011, 02:55 PM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
When was the last time you had it hooked up to your other truck? Are you using the 4 pin or 7 pin connector or some sort of adapter? Have you used a multi meter to make sure you are getting power at the plug when the tails, blinkers, and flashers are on? If not, those would be some things I would check.
Check this link for which wires operate each light.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
electrical, lights, trailer connector, wiring
trailer wiring running lights? SportHD Custom Dodge Ram Interior and Exterior Lighting 5 06-14-2011 01:45 PM
Trailer lights problem please help joeyjrc Newbie Checkin! 11 06-13-2011 11:09 PM
Make a wiring adapter to convert 4 pin trailer lights to 7?? kdanderson5 Dodge Ram General Discussion 3 12-28-2010 02:40 PM
2003 ram 3500 trailer lights problem 2003duallyram Custom Dodge Ram Interior and Exterior Lighting 5 11-27-2010 11:10 AM
another trailer lights problem scbachman Newbie Checkin! 3 06-09-2009 08:55 PM
