Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
tonneaucovered.com
View Poll Results: What is your favorite thing about your Dodge Cummins Diesel?
The sound of the turbo 1 100.00%
The raw power 0 0%
The looks you get from envious GM and Ford owners 0 0%
The price of fuel 0 0%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
Old 07-29-2011, 03:45 PM
truthguru truthguru is offline
Vehicle: 2007 Dodge Ram
Trim Level: standard
truthguru is on a distinguished road
Default Left brake and turn signal
I'm having a problem with my left side only turn and brake lights.
I've tried the following to correct the issue:
Checked both bulbs - visibly, ohmed and inserted new
Checked voltage at outlet - 9.2 - to low to burn a 12v bulb
Checked fuse in mtip (integrated power module) is good
Checked wiring and harness from assembly at rear all the way to the mtip and it is in stellar condition - like new
Checked brake switch - when i was screwing around with this part, i turned the lever on the switch and magically the brake light and turn signal began to work again. I thought the problem was solved. I turned off the ignition, removed the key, confirmed all lights were off and with puffed up chest strutted inside for the evening. About an hour later I get a knock at the door and my neighbor was alerting me that the running lights were on. I went out to confirm and could not get them to turn off, so i raised the hood and pulled the fuse til morning. When I put the fuse back in the original problem surfaced again.
The most annoying part of this whole ordeal is the incessant alarm that sounds every time I engage the brakes or turn signal and since I've been doing a lot of city driving lately It's driving me batty.
Any ideas?
P.S. I reviewed Haynes manual, researched the dodgebodybuilder.com site and have not been able to lock in on a possible cause and solution.
Thanks for the help in advance
Old 07-29-2011, 04:00 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
First of all, why is this thread a poll?
My brother has a truck similar year to yours, might be an 06, not sure, but he had weird electrical issues that didn't make any sense, something to do with a bad switch in the steering column, or maybe in the dash, can't remember. Also could be a ground. Beyond that I'm not much help...I'd start with the grounds and checking those.
Sean
Old 07-29-2011, 04:10 PM
Default Thanks
I just found another forum that mentions the multi function switch in the column. Seems like the next logical place for me to look
Thanks for the heads up
Old 07-29-2011, 04:14 PM
snrusnak's Avatar
Rep:1385
you jogged my memory, that is what his problem was...he'd put on the turn signal, and his wipers would come on, or high beams, or something weird like that...
Sean
Old 08-01-2011, 04:22 PM
Twin4573's Avatar
Twin4573 Twin4573 is offline
Vehicle: 2005 Dodge Ram
Twin4573 is on a distinguished road
Wow I have the same problem! I am about to change the switch today. I have a 2005 Quad 4x4 5.7. I have no rear brake light nor turn signal. The driver's side front flasher will blink fast. I hope this solves this issue.
Trailer turn signal not working EBK142 Electrical 10 03-19-2012 07:52 PM
Turn Signal Short Knoxgeek Electrical 1 06-30-2011 02:10 PM
right trailer turn signal wire redeye4u Electrical 27 05-27-2011 10:57 PM
Break light & turn signal problem Tin Can Man Electrical 1 05-19-2011 12:37 AM
2010 Dodge Ram..Turn signal circuit MangoRam Electrical 4 03-29-2010 07:15 PM
