Old 07-29-2011, 08:02 PM
Firefighter4547 Firefighter4547 is offline
Vehicle: 2011 Ram 1500
Trim Level: BIGHORN
Color: Deep Water Blue Pearl
Firefighter4547 is on a distinguished road
Default Exhaust
Question. I got the Magnaflow cutback with the 22' muffler. Should I use the clamps to bolt it on or should I have it welded and why? Please reply asap. Thanks!!!
Old 07-29-2011, 08:14 PM
Jixer's Avatar
Jixer Jixer is offline
Vehicle: 2011 Dodge Ram
Trim Level: Big Horn quad cab
Rep:112
Jixer will become famous soon enoughJixer will become famous soon enough
Weld it...eliminates exhaust leaks
Dave
K&N series 63 CAI - 22" Magnaflow muffler - MyGiG Lockpick V.4 - Rhino spray in bedliner - Truxedo LoPro tonneau cover - front and rear view cameras - side steps - tow hooks - skid plates - slush mats
Old 07-29-2011, 09:24 PM
Trim Level: BIGHORN
Where is the Y located? Before or after the cats?
Old 07-29-2011, 09:47 PM
Razorbass's Avatar
Razorbass Razorbass is offline
Woo Pig Sooie!
Vehicle: 2011 Dodge Ram 1500 Laramie
Rep:95
Razorbass will become famous soon enough
After. Don't cut the cats unless you understand your local laws.
2011 Laramie Crew Cab 4x4, skid plates, 3.92 gears, Magnaflow cat back, spray-in bed liner, debadged, Bakflip F1 tonneau cover, WeatherTech liners & deflectors, K&N drop-in filter, 20% tint, Sickspeed carbon fiber antenna
Old 07-29-2011, 10:11 PM
Lothario80 Lothario80 is offline
Vehicle: 2011 Dodge Ram Crew Cab
Color: Mineral Grey Metalic
Rep:41
Lothario80 is on a distinguished road
Originally Posted by Razorbass View Post
After. Don't cut the cats unless you understand you local laws.
Speaking of which and not trying to hijack but will it void my warranty or throw codes if I put in an aftermarket y to replace the stock? Had a muffler shop tell me it will and I'll be throwing codes.
K&N CAI - Magnaflow 18" - Putco In-Channel Vent Visors - Truxedo Lo-Pro Tonneau - 5" Carbon Fiber Antenna - Timbren SES - Smoked Tails & 3rd - Overhead 13" DVD - CHR550 Lockpick - DeBadged
Old 07-30-2011, 12:19 AM
HEMILANCER's Avatar
Vehicle: 09 Dodge Ram
Color: deep water blue
Rep:85
somebody correct me if i'm wrong but isnt the dual exhaust setup stainless steel? if it is then welding the joints will cause the stainless to lose it's properties and cause rust.
Too many mods to fit here!
Old 07-30-2011, 12:24 AM
Trim Level: BIGHORN
Yes it is stainless steel, but isn't the stock exhaust welded?
Old 07-30-2011, 12:33 AM
HEMILANCER's Avatar
Rep:85
no it's all bolted together so it won't ever rust.
Old 07-30-2011, 01:19 AM
riggz riggz is offline
riggz is on a distinguished road
I prefer the clamps so that I can take it off and sell it if I ever decide to sell the truck or go a different route with the exhaust. I just traded in my Infiniti M45 and I took off the Stillen exhaust I had on it so I can sell it.
Old 07-30-2011, 02:49 AM
P Rod's Avatar
P Rod P Rod is offline
Vehicle: 2011 Ram 2wd Crew Cab
P Rod is on a distinguished road
If you can find a muffler shop that uses Stainless steel mig wire and a Argon/CO2 gas mixture you will not contaminate your Stainless steel. If they only use regular steel wire then yes, the welds will eventualy rust. The same goes with Tig welding. And if you want to get picky use only a new stainless wire brush to clean your welds. I haven't been to a muffler shop in years so Im not sure if any use Stainless Steel. It might be worth asking around.
CrewCab Sport*Sunroof* Navi*3.92's*Ground Force 2/3 drop*Back Flip F1*Mufflex 18"*BedTred
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 05:16 PM
2008 4.7L - Single or Dual Exhaust? ctroxell Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 25 05-26-2012 10:33 PM
Exhaust Questions, concerns, and general stuff that has been stated time and time ShotGunWillie Exhaust 12 12-08-2011 01:07 AM
exhaust question Quiet Lunatic Exhaust 8 01-19-2010 11:22 PM
FS: 2004.5-07 5.9L Bullydog Turbo-Back 5" Exhaust with 6" Polished Tip Justin@AACstyle.com Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 0 12-22-2009 02:37 PM
