nitto 295/55/20 vs 295/60/20 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 07-29-2011, 08:39 PM
seabass seabass is offline
Vehicle: 2008 dodge ram
Trim Level: laramie
Color: silver
seabass is on a distinguished road
Default nitto 295/55/20 vs 295/60/20
Just as title states....nitto makes the trail gtappler mt now in 295/60/20.... Will these fit on an 08 laramie 4wd with no rub?? I know the 295/55 will bit if the295/60 does then i want it for the height....thanks guys!!!!!
Old 07-29-2011, 08:44 PM
Rep:3347
It'd be hit or miss. 33s no problem, some people are able to fit 35s with no rubbing, but most do require a front level. I'd say order the 295/60s and if you DO rub, then spend the $100 and get a front level spacer. But, if you're gonna need a spacer, you may as well just go to 35s.
Old 07-29-2011, 09:13 PM
Trim Level: laramie
Color: silver
Forgot to mention I was gonna do bilstein upgrade.....oooops....
Old 07-29-2011, 09:24 PM
Rep:3347
You might want to look at 35s then. They're more common and should be a bit less than a 34" odd-ball size that not many manufactures have. But if you're doing the Bilstein upgrade then you'll have no problems getting those under there with no rubbing.
Old 07-29-2011, 10:02 PM
Trim Level: laramie
Color: silver
Sounds like more money at the pump but if I was really concerned about it i woulda bought a prius..... So a 35 will fit...what width should i run???
Old 07-30-2011, 08:11 AM
BigHorn 4 Life's Avatar
Color: Briliant Black
Rep:463
12.50's if you go any bigger it will rub.
Old 07-30-2011, 12:29 PM
RamU's Avatar
RamU RamU is offline
Vehicle: 2008 Dodge Ram
Rep:40
RamU is on a distinguished road
You can fit the 35's on a leveled truck but you also have to worry about rubbing on the upper control arms! With a 295 you are going to need 1/4" wheel spacers with the stock wheels(need more negative offset), unless of course you're getting new wheels also!
2008 Dodge Ram 1500 QC Hemi 4x4
Old 07-31-2011, 08:56 PM
Trim Level: laramie
Color: silver
i m getting the tires from discount tire ..do they have spacers or does someboby recommend a certain company????need an answer was going to order the tires tomorrow....pls help you guys have been awesome already...thx
Old 08-03-2011, 01:22 PM
Torq89 Torq89 is offline
Vehicle: 2005 Ram 2500
Color: Grey
Rep:87
Torq89 will become famous soon enough
Discount Tire will not let you run spacers on your truck if they put the tires on. I bought my terra grapplers from them and about 2 weeks later put some spacers on. When I went to get my tires rotated (free since I bought the tires from them) they took all my spacers off and told me I could not have them on if they are going to be working on my truck. That even came from the head manager who ran the store. I guess it's some kind of policy the company has.
295/60/20 Nittos on 07 RAM VanillaHemi07 Dodge Ram Wheels And Tires 36 04-08-2012 02:44 PM
Nitto Terra Grappler - 295/60/20 - Pictures ABD26 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 12 09-06-2011 11:34 PM
Nitto Terra Grapplers??? brc3858 2010 Dodge Ram Forum 13 04-29-2011 09:49 PM
295/60/20 Nitto Trail Grapplers!!!!! VanillaHemi07 Body & Interior 10 04-08-2011 10:35 PM
Nitto Trail Grappler or Nitto Terra Grapplers, who's had em both? ohnoesramtruck Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 18 07-26-2010 04:12 PM
