Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 07-30-2011, 05:57 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PXR Black
Rep:2477
Glad you were able to find it. Wish mine had a drain plug, unfortunately only the fill plug is on mine. I want to change my fluid to synthetic and will either have to pump it out our take the cover off.
Old 07-31-2011, 12:00 PM
Stainless's Avatar
Stainless Stainless is offline
Vehicle: 2011 Dodge Ram
Color: Bright white
Rep:13
Stainless is on a distinguished road
Originally Posted by Bert66 View Post
Your truck needs the recall done.
Old 07-31-2011, 12:09 PM
Longhorn2011 Longhorn2011 is offline
Trim Level: Laramie Longhorn
Color: White/White Gold
Longhorn2011 is on a distinguished road
His doesn't have the recall since it was built in Feb 2011.
Old 07-31-2011, 05:32 PM
Stainless's Avatar
Color: Bright white
Rep:13
Yep your right, I need to remove one of these covers on the newer trucks and see what they did to correct this. I apologize i didn't see the build date.
Old 07-10-2012, 09:31 PM
fullmonte60's Avatar
fullmonte60 fullmonte60 is offline
Vehicle: 2011 Ram 1500 Express
Rep:19
fullmonte60 is on a distinguished road
i have a drain plug not on the cover, just in from the cover on the housing. drain plug is the same size as the fill plug. anyone have any idea what hex size it is. my largest is a 10 and it's way too small. thank you.
2011 Ram 1500 Express, Hemi, Black, Jet PCM, Airaid, Magnaflow 10778 & 12198, BT catch can, Bed Armour, Lund Genesis Tri-Fold, Debadged.
Old 07-10-2012, 09:41 PM
Rep:19
BTW- Here is my axle info from the build sheet>
DMDS 3.55 Rear Axle Ratio
DRNS 245MM REAR AXLE
DS8S Conventional Differential Rear Axle
Old 07-10-2012, 11:18 PM
wbowyer wbowyer is offline
Vehicle: 2011 Dodge Ram 1500
Color: Inferno Red
Rep:71
wbowyer will become famous soon enough
It may be because you have the 3.55 rear end. I know my truck was built in late March/early April and I have the drain plug on the rear of my differential; however, I have the 3.92 rear end.
Old 07-12-2012, 12:31 AM
caseykerner caseykerner is offline
Rep:88
caseykerner will become famous soon enough
9/16" hex. Just pulled my cover to inspect and change juices.
Old 07-12-2012, 03:28 AM
Rep:2804
Sorry, i don't trust Ram as far as i can throw a house
If your fill plug is not real close to the center of the axle tube, it won't give the axle bearings out by the wheels enough lubrication
the Recall was because the fill plug was only about an inch or less from the bottom of the axle tube, if you were driving on a road that makes your vehicle tilt a bit, the axle bearings on the high side would not be getting any fluid.
The dealerships were told to take off the vent tube that is on the very top of the axle tube & add something like 8 ounces of fluid, until the replacement rear cover with the slip in plug was installed
this was only on Rams with the new ZF 245mm rear end
The older Corporate 9.25 rear ends came out with a plug at the proper level
Personally, i went out & purchased a rear differential cover that has a fill & drain plug
the drain plug is magnetic & it will grab any metal filings that may be in there
So now i can drain the oil, check the drain plug & refill the rear differential without pulling the cover, if there are no metal filings
pulling the rear cover, buying a new gasket, applying the sealant, Then refilling the fluid is an extra cost that i didn't want & then the wasted time involved
I went with a fancy cover, but you can get them cheaper, but mine is cooler
By the way, the Generation 4 rear ends all have synthetic fluid in them, i won't begin to say about 2008 & older
Old 07-12-2012, 08:26 AM
Rep:19
thank you both. i'll take some pics.
Major breakdown!!!! Transfer case, tranny, drive shaft, rear diff..... MRP 2010 Dodge Ram Forum 29 08-12-2015 03:14 AM
5.2/5.9 Misfire TSB 18-48-98 RamTech Dodge Ram Knowledge Base 3 06-22-2014 07:45 AM
Differential fill plug OregonTRX4 2010 Dodge Ram Forum 10 12-26-2011 01:14 AM
1st Oil Change BLKSPORTHEMI Oil Change 41 10-12-2011 07:53 PM
Rear bumper trailer plug? 11HEM1 5.7L V8 Specific Topics 1 01-20-2011 02:32 PM
