Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Place your Ad Here!
Old 07-12-2012, 09:28 PM
fullmonte60's Avatar
fullmonte60 fullmonte60 is offline
Vehicle: 2011 Ram 1500 Express
Rep:19
fullmonte60 is on a distinguished road
all done. our friends up north can use a 14mm. mine was built 4/2011.
2011 Ram 1500 Express, Hemi, Black, Jet PCM, Airaid, Magnaflow 10778 & 12198, BT catch can, Bed Armour, Lund Genesis Tri-Fold, Debadged.
Old 07-14-2012, 10:01 PM
Rep:19
do the differentials with the recall have a rubber plug in the top hole instead of the screw in?
Old 07-14-2012, 11:44 PM
Gantman's Avatar
Gantman Gantman is offline
Vehicle: 2016RCLB4x4/44-45
Trim Level: Tradesman w/3.92 LSD
Rep:999
fullmonte, the recall showed the replacement of the entire rear diff cover along with a rubber fill plug which was positioned just above half way up the cover itself. If you've got two hex head plugs as indicated in the pic, your rear diff is most likely the newer design after the recall.
Total Chaos UCA's, Fox 2.0 IFP Coilovers and shocks, TTC-1223V variable rate coil springs.(Mods list)
Old 07-14-2012, 11:56 PM
Rep:19
thanks. i was hoping someone would tell me dodge slipped an old dana rear under there...lol
Major breakdown!!!! Transfer case, tranny, drive shaft, rear diff..... MRP 2010 Dodge Ram Forum 29 08-12-2015 03:14 AM
5.2/5.9 Misfire TSB 18-48-98 RamTech Dodge Ram Knowledge Base 3 06-22-2014 07:45 AM
Differential fill plug OregonTRX4 2010 Dodge Ram Forum 10 12-26-2011 01:14 AM
1st Oil Change BLKSPORTHEMI Oil Change 41 10-12-2011 07:53 PM
Rear bumper trailer plug? 11HEM1 5.7L V8 Specific Topics 1 01-20-2011 02:32 PM
