Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 07-30-2011, 04:53 PM
BradC BradC is offline
BradC is on a distinguished road
Default Hellwig Sway Bars
I just installed a Hellwig rear sway bar on my 2010 1500. I was amazed at the difference in handling. Well worth the money!!
They sell a front sway bar as well which is tempting given how impressed I am with the rear. I'm guessing though that the benefit won't be as much as the rear over stock but I can't seem to find much info on it searching around.
Anyone running an upgraded front sway bar and was it worth it?
Thanks!!
Old 07-30-2011, 05:29 PM
Hellwig makes good stuff! That's an excellent choice.
Actually, a nice stiff front sway bar is a huge upgrade. It improves directional stability, will improve the body roll in the front and if you have already done the rear, you have introduced some understeer. The front bar will correct that and make the handling much more neutral with good feedback and instant centering of the steering wheel.
I'd go for the front one too.
Old 07-30-2011, 05:39 PM
FDBDW's Avatar
FDBDW FDBDW is offline
Vehicle: 2009 Dodge Ram
Trim Level: Big Horn, 5.7 hemi
Color: BRILLANT BLACK CREW CAB
Rep:172
FDBDW has a spectacular aura aboutFDBDW has a spectacular aura about
Im interested, how was the install , any pics.
I was always told that your front sway bar needs to be a little bigger
than your rear sway bar , can anyone confirm that
MOPAR CAI , 14" MUFFLEX, Diablo Intune 91oct , 2.5" LEVEL, K2 OPEN BLACK MESH GRILLE, FRONT WINDOWS TINTED, ROCKSTARS ON 295/70/18 NITTO TRAIL GRAPPLERS, LARADO BED COVER, DEBADGED, GO RIHNO STEPS , RECON SMOKED TAIL & THIRD BRAKE LIGHTS , PAINTED HEADLIGHTS , SPEEDLOGIX CATCH CAN, FASTMAN PORTED TB ,
Old 07-30-2011, 08:44 PM
Cool, thanks for the reply. That makes perfect sense. I am noticing the front feels a little loose now after I've run it through a few corners. Not bad by any means but compared to how the rear feels now. I think I'll go ahead and do it.
The install could only have been easier if I had been sitting in a chair with a beer watching someone else do it. It was very simple. There are 6 bolts to take out the stock bar and the new one bolts right back in the same place using the same bolts. It probably took me a half an hour or so. I can take a picture when I get a chance but it's basically the same as the stock one only a larger diameter.
You're right that the front one is heavier than the rear.
Old 07-30-2011, 09:16 PM
mc1hd mc1hd is offline
Vehicle: 2011 Dodge Ram R/T
Trim Level: R/T
Rep:27
mc1hd is on a distinguished road
Anyone install these on the 2011 1500's ? I would think they would be the same but their only listed for the 09 & 10's.
Old 07-31-2011, 01:56 PM
Here are a couple of pictures of the rear sway bar.
The front one is on order so I'll post pics before and after installation when I get it.
Old 08-06-2011, 09:50 PM
fullmonte60's Avatar
fullmonte60 fullmonte60 is offline
Vehicle: 2011 Ram 1500 Express
Rep:19
fullmonte60 is on a distinguished road
i just a hellwig 7709 for mine. will i need to pickup end links or do they come with the kit? thanks.
2011 Ram 1500 Express, Hemi, Black, Jet PCM, Airaid, Magnaflow 10778 & 12198, BT catch can, Bed Armour, Lund Genesis Tri-Fold, Debadged.
Old 08-08-2011, 07:28 PM
You re-use the stock end links and all the bolts. I would be curious to know if replacing the end links would be any better. I'm so impressed with the difference as it is I would be surprised if it did but if anyone knows please chime in.
I got the front bar on this weekend but I did it late at night (was the only time I had to work on it) and completely forgot to take pictures during - DUH!! Sorry if anyone was waiting for them but the install was basically the same as the rear. It was a little harder though mainly because the access space is more limited. You need to turn the wheels in each direction to get to the end link bolts. Plus, the front bar is of course a lot heavier than the rear so getting it up in place is more of a challenge without help. I did it by myself and had to use jack stands to hold it in place. Also the front one is orientation specific at the end links so take note of how the stock one comes out. Bring it straight down and leave it on the floor in the right orientation so you can compare it to the new one. The instructions don't help with that.
The front bar made a nice difference in handling. Not as significant as the rear did from stock but still well worth the investment.
Old 08-08-2011, 11:10 PM
Well, did you have a stock rear sway bar?
Old 08-08-2011, 11:35 PM
Rep:19
i'll have to call hellwig tomorrow. i sent an email but never heard back. depending on where you read their literature, sometimes it seems like it comes with the end links and sometimes not...lol.
ram express bolts, rear sway bar
Hellwig sway bars and Borla NMMI89 Suspension 1 03-05-2011 06:04 PM
new for 09-10 ram sway bars - addco SPEEDFREAK Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 16 01-05-2011 08:03 PM
ram rt ordered new sway bars, drop kit, shocks SPEEDFREAK Dodge Ram R/T 14 09-08-2010 12:17 PM
sway bars strang3majik Suspension 0 06-10-2010 02:28 AM
Sway bars RadRam Dodge Ram General Discussion 1 11-17-2009 09:09 AM
