Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 01-03-2012, 08:54 PM
HoustonHemi's Avatar
HoustonHemi HoustonHemi is offline
Vehicle: 1492 Santa Maria
Color: Hot pink
Engine: 1981-1987 225ci (3.7L) Slant-6 95hp
Rep:135
HoustonHemi will become famous soon enoughHoustonHemi will become famous soon enough
Just received my Hellwig front S-bar today,,,
Oh, My, GAWD!!!! Talk about CHUNKY
Looks like it should be installed on a Freightliner, and not on a RAM!!!!
(And yes, I have worked on Freightliners!!!!!)
Old 01-30-2012, 10:07 PM
jmr's Avatar
jmr jmr is offline
Vehicle: 2016 RAM 1500 Express QC 4WD
Trim Level: Express Quad Cab
Rep:77
jmr will become famous soon enough
My son and I installed the new Hellwig #7708 front sway bar, it's a big piece of steel and dwarfs the stock 1 1/4" bar
and is really 1 1/2" even though the catalog says 1 7/16". I bought it from Amazon.com for $193 shipped, it came
with 2-Black poly bushings, 2-D brackets and a tube of Green bushing grease...a really good kit.
Prior to this I added the OEM 16MM rear bar so this really completes the handling package. Hellwig makes
a 7/8" rear bar #7709 but since my truck is a reg cab short bed I worry that too big a rear bar would induce oversteer.
'16 RAM 1500 Express QC 4WD 5.7L, 8SPD, 3.21 W/LSD Red Calipers, K&N Filter, 4" AirBox Intake Tube, Cabin Air Filter, Leather Steering Wheel w/Radio Controls, Mopar Bed Liner/Mud Guards/Skid Plates, Lund Tri-Fold Cover, Black RAM Emblems, Homelink Overhead Console
Old 01-31-2012, 08:56 AM
fullmonte60's Avatar
fullmonte60 fullmonte60 is offline
Vehicle: 2011 Ram 1500 Express
Rep:19
fullmonte60 is on a distinguished road
i had seen a similiar rear kit on amazon for about $170.
2011 Ram 1500 Express, Hemi, Black, Jet PCM, Airaid, Magnaflow 10778 & 12198, BT catch can, Bed Armour, Lund Genesis Tri-Fold, Debadged.
Old 07-30-2012, 05:53 PM
Firehawk's Avatar
Firehawk Firehawk is offline
Vehicle: 2011 Dodge Ram
Trim Level: Express RCSB/2WD
Color: Mineral Gray Metallic
Firehawk is on a distinguished road
Send a message via Yahoo to Firehawk
Originally Posted by HoustonHemi View Post
To recap, (2) part number 1-68041718AC (link w/hardware) and (4) 6502467 (U-clamp to differential housing bolts) are all the OEM parts you need to install an aftermarket rear sway bar to a 4th Gen RAM 1500 that was not equipped with one from the factory.
Thanks, I just got off the phone with the dealership and they told me I was also going to need two of these part numbers below (they didn't mention 6804178AC you have above):
2x 6104238AA ?
2x 6508965AA ?
Any ideas? I am going to try to look up what these two part numbers above are...
http://www.usa-auto.ru/p145286C2009.html
↑↑↑↑↑↑ My truck modifications list is located in my forum profile. → → →
Old 07-30-2012, 06:09 PM
Color: Hot pink
Rep:135
Google those numbers and you get 'bolt' and 'nut'
Parts 2, 3 and 5 came with my link (4)
Helwig supplied 1, 8, and 7. I bought (4) of 6
As indicated, (2) of one part number (link w/hardware) and (4) of the other (bolt) are all ya need from Dodge.
Buying parts at the local dealer!?!?!?!
Better check online if you have time and want to save a buck or 2
Again, Google the part number. 1st 'hit' came back with this:
Home > Mopar Parts > STABILIZER BAR LINK > Mopar Part 68041718AC STABILIZER BAR LINK
Item# 68041718AC
Dealer price: $42.10
Our price: $29.80
Old 07-30-2012, 06:24 PM
jacksonsnorth's Avatar
jacksonsnorth jacksonsnorth is offline
Vehicle: 2012 Dodge Ram 1500 QC 4wd
Rep:69
jacksonsnorth will become famous soon enough
Originally Posted by BradC View Post
I just installed a Hellwig rear sway bar on my 2010 1500. I was amazed at the difference in handling. Well worth the money!!
They sell a front sway bar as well which is tempting given how impressed I am with the rear. I'm guessing though that the benefit won't be as much as the rear over stock but I can't seem to find much info on it searching around.
Anyone running an upgraded front sway bar and was it worth it?
Thanks!!
I have used Hellwig products on 2 Rams since 2004 and love them. I really was impressed whti the Hellwig pring helpers I put on to help pull my 33ft TT on my 04 ram 1500 with 4.7.....thats right 4.7, and I gotta tell ya aside from gas mileage that truck was the best I ever owned. I am gonna cry ....J/K. At any rate, the Hellwig products rock, I cant say enough good things about them.
The Rammin' Fool from Maine
Stubby Antenna, Bed Net, Toyo Open Country tires, Bilstein 5100 Ride Height adjustable set at 2.1 ..Tow Hooks in house ready for install. More to come!
Old 07-31-2012, 11:16 AM
jmr's Avatar
jmr jmr is offline
Rep:77
I have installed the factory rear swaybar on mine and it was 16MM. I would not goes this route again use HELLWIG instead it's larger and has 3 adjustments for length.
If you go the HELLWIG route you will only need these factory parts: two of part # 68041718AC rear Sway bar Link Kits that are $28.18 each they are item 4 on the picture.
Old 09-03-2012, 01:45 AM
arlockstedt arlockstedt is offline
Vehicle: 2009 Dodge Ram 1500 CC Hemi
arlockstedt is on a distinguished road
Definitely want to get a set of these!!
Old 09-10-2012, 07:38 PM
Edgethis's Avatar
Edgethis Edgethis is offline
Color: Blue
Edgethis is on a distinguished road
Just curious, what is the other hole for on the sway bar?
Would this work with a leveling kit like Rough countrys that lifts the rear a bit?
ram express bolts, rear sway bar
Hellwig sway bars and Borla NMMI89 Suspension 1 03-05-2011 06:04 PM
new for 09-10 ram sway bars - addco SPEEDFREAK Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 16 01-05-2011 08:03 PM
ram rt ordered new sway bars, drop kit, shocks SPEEDFREAK Dodge Ram R/T 14 09-08-2010 11:17 AM
sway bars strang3majik Suspension 0 06-10-2010 01:28 AM
Sway bars RadRam LD RAM - General Discussion 1 11-17-2009 09:09 AM
