32 Gallon Tank - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 07-30-2011, 04:37 PM
ryan2001 ryan2001 is offline
Vehicle: 2011 Ram 1500 4x4
Trim Level: Outdoorsman
Color: Hunter Green
Rep:31
ryan2001 is on a distinguished road
Default 32 Gallon Tank
Hi All,
Got a question for those of you with a 32 gallon tank....It does not seem to hold the claimed volume. I filled up the for the first time and only got 24 gallons in it and the DTE read 45 miles to Empty.....I am sure that there is a saftey factor built into that number but the gauge was at about 1/8th of a tank. Also, when the pump clicks off it is indeed full. I tapped it a few more times as I usually do and it all came back out the filler neck. Lots of vapor line to bleed off i guess.
Any help?
Old 07-30-2011, 04:47 PM
Razorbass's Avatar
Razorbass Razorbass is offline
Woo Pig Sooie!
Vehicle: 2011 Dodge Ram 1500 Laramie
Rep:95
Razorbass will become famous soon enough
That doesn't sound right. I have the 32 and have put over 30 in it when it was really low. I knew that was right cause it cost me over $100 to do it LOL. Are you positive they did not put the smaller tank in yours by mistake? The only other option is your EVIC may not be calculating the DTE properly. You can also take it to the dealer and they should be able to tell just by looking at the tank.
2011 Laramie Crew Cab 4x4, skid plates, 3.92 gears, Magnaflow cat back, spray-in bed liner, debadged, Bakflip F1 tonneau cover, WeatherTech liners & deflectors, K&N drop-in filter, 20% tint, Sickspeed carbon fiber antenna
Old 07-30-2011, 04:50 PM
Color: Hunter Green
Rep:31
I was thinking the same thing....... How many miles to Empty do you typicaly see after you fill up on the display. I think i am going to go to the dealer and climb under a few trucks to see the diffrences in the tanks and compare them to mine.
Old 07-30-2011, 04:53 PM
Razorbass's Avatar
Woo Pig Sooie!
Rep:95
I never get that low on gas. I only burn about 1/4 to a 1/2 tank each week driving to/from work so I just make sure to tip the tank off every weekend. Also, the 32-gallon tanks have a known problem of making a thud sound from the gas sloshing around if you let it get below a 1/2 tank.
Old 07-30-2011, 04:57 PM
anoldbiker anoldbiker is offline
Vehicle: 2006 Dodge Ram Quad Cab
Trim Level: SLT Big Horn
anoldbiker is on a distinguished road
I had a 35 gallon tank before I changed out to a 60. The tank manufacture told me the volume of all tanks are what is advertised plus 10 percent volume for vapor space.
With my 35, when I hit full, or the fill nozzle clicked off, I was able to put in another 3 to 4 gallons to top it off before a long run. On my 60, the ratio is the same. When it clicked off, I added roughly 6 gallons. Now I have diesel, but a fuel tank is a fuel tank.
As for the overhead display, I learned to have no faith in it. With my 60 gallon tank, on the last run, it said I had 548 miles to empty when I filled, and I drove from Nashville to after Amarillo. I had 1,015 miles on the trip-o-meter, and the tank was showing 'E'. Sort of well past 548 miles indicated by the overhead.
Old 07-30-2011, 11:54 PM
estoltz estoltz is offline
Vehicle: 2011 Dodge Ram 1500 5.7 4x4
estoltz is on a distinguished road
I have the 32 and it will run down to Low for a while. I have only done it once because you risk burning up the fuel pump if you let it run down that much.
Old 07-31-2011, 12:27 AM
DOZER's Avatar
DOZER DOZER is offline
Vehicle: 2009 Ram 2500 Quad cab 4x4
Color: Inferno Red
Rep:140
DOZER will become famous soon enoughDOZER will become famous soon enough
Send a message via Yahoo to DOZER
In my experience with these Gage's they never read correct. In my '98 it would take forever to drop to the half way mark and then you could almost see it drop to empty. It had the 26gal tank. On my '06 it's the opposite drops real fast to the half way point and takes forever to get to empty. It has the 34gal tank. I try to never let it get below 1/4 tank. When it gets to 1/4 I fill it up and it takes 22gals. A 1/4 tank should be 8.5 gals which makes 30.5gals so the gage is off 3.5gals somewhere.
'06 2500 ST 4x4 Quad cab, Vararam CAI, Bed/Hood stripes, Vent visors, Bully tailgate lock, Moto Metal 909 18x9, Nitto Terra Grapplers 295/70/18 HBS 2" level, Bilstein 5100's, Bushwhacker flares, 5000K HID's, Diablo Trinity 87 tune, LineX, Bakflip F1.
Old 07-31-2011, 11:00 AM
fier23's Avatar
fier23 fier23 is offline
Vehicle: 2011 Ram 1500 Laramie CC
Color: Deep Water Blue Pearl
Rep:15
fier23 is on a distinguished road
My first fill up I had the same experience. Near empty it only filled 25gal. After that I was putting in 30+ gal. Strange.
Jeremy
Old 08-01-2011, 02:03 AM
No Fear In Texas No Fear In Texas is offline
Vehicle: 2011 Dodge Laramie Longhorn
Trim Level: Longhorn 1500
No Fear In Texas is on a distinguished road
I kind of noticed something like that but wasn't really paying attention to it. I will have to pay more attention when I go to fill her up.
Fuel Fill Nozzle Shuts Off RamTech Dodge Ram Knowledge Base 3 11-22-2013 10:22 PM
Adding a spare diesel tank. casper5280 Cummins Diesel Specific Topics 3 01-31-2012 07:32 PM
32 Gallon Gas Tank Fury 2010 Dodge Ram Forum 23 08-31-2010 08:06 AM
Really? 26 gallon tank? 98sst Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 12 01-22-2010 12:56 AM
Fuel fill problems RamTech Dodge Ram Knowledge Base 3 01-09-2010 11:38 AM
