Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 07-30-2011, 04:52 PM
rickel89 rickel89 is offline
Vehicle: 1991 Dodge Ram D150
Trim Level: Standard package
Color: Electric Blue
rickel89 is on a distinguished road
Default 1991 Dodge D150 318 CI dies when sitting idle.
1991 Dodge D150 318 CI dies when sitting idle, then it will not start. I have to raise the hood and let it cool down for 20 - 30 minutes. After it cools down it runs fine. It has done this a couple of times last summer and then again today. I do not think it is vapor locking. I removed one of the fuel lines to check for fuel and pressure. I had my son turn the ignition on while I held a bottle over the fuel line and the open port on the carbureator. I am getting plenty of fuel. I think it is something electrical breaking down under the extreme heat when sitting at idle and no movement of air. It has a new battery. New air pump that is one year old now. The temperature gauge is normal and not overheating when this happens. Would someone please share your experiences that might be the same as this one. I would like some tips for troubleshooting to minimize what it could be. It is hard to troubleshoot because it will fix itself. Thanks everyone in advance for all the help
Old 07-31-2011, 02:22 AM
Reddog170 Reddog170 is offline
Vehicle: 1996 Dodge Ram 1500
Color: Hunter green
Engine: 1993-1993 360ci (5.9L) Magnum V8 230hp 325lb/ft
Rep:21
Reddog170 is on a distinguished road
I had a race car that would do that if we were stuck in staging to long. Did not do it every time so like yours it was hard to diagnose. Turned out with me it was a problem with the coil. Might be the same might not, but that is about the best I can do for you. Hope it helps, Shaun
Old 09-12-2012, 10:43 PM
gregm gregm is offline
Vehicle: 1991 dodge D150
Trim Level: le
Color: two tone red/white
gregm is on a distinguished road
I had a 87 bronco did that, found that the muffler or catalitic was stopped up. it would run fine and then go to crap. when it cooled it was ok
Old 09-13-2012, 03:47 AM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
If you have a carb, it's been modified and no telling what the issue might be. If you're affectionately referring to the TBI as a carb, then I'd say your Hall Effect (aka distributor ignition pickup) is failing. They become more sensitive to heat once they begin to fail and will reset and function to varying degrees, becoming less reliable as they go. It's about $30, fits inside distributor, beneath rotor.
Old 09-18-2012, 10:23 PM
arvonian arvonian is offline
Vehicle: 1995 Dakota, 1988 Power Ram
arvonian is on a distinguished road
I just posted about the repairs made to my 88 Ram with throttle body. I was experiencing vapor lock when hot, and even though I had fuel pressure, it was not high enough to circulate gas back to the tank. I found that there was a split in the hose connected to the fuel pump inside the tank, I was only getting around 13 psi at the tank. Try hooking up a pressure gauge to the 5/16" hose coming out of the fuel tank. the pressure should be around 70 psi. (be sure to tighten all connections before checking!) You could also hook up a gauge to the inlet hose to the TB and plug one end....
Old 09-29-2012, 11:07 PM
streetvan1 streetvan1 is offline
Vehicle: ugly 88 ram
Trim Level: ROYAL s.e.
Color: White/brown
streetvan1 is on a distinguished road
+1 for this answer. Common failure, with symptoms exactly as you described. And also, if you're playing the guessing game and changing parts, this is one of the cheapest, and easiest to change. It'll kill spark and injector pulse, by denying the computer a tach signal, and almost always be intermittent, becoming worse over time. Fixed my truck, and a couple like it. Also common on older GMs and Ford distributors.
Old 07-31-2013, 02:57 AM
theresadeno@gmail.co theresadeno@gmail.co is offline
Vehicle: 2001 Dodge ram
Trim Level: fleet
theresadeno@gmail.co is on a distinguished road
Default 2001 ram won't start
Just like the others in this thread, it got worse in the heat and then someone siphoned all my gas (ouch) and after adding more fuel it still won't start. "no bus" is on. I have fuel injection tho.
Old 07-31-2013, 09:35 AM
Rep:85
"No BUS" could be a bad connection with the power distribution center or a bad computer.
Extended fast idle - 2008 dodge ram 1500 hemi OLDTECH 5.7L V8 Specific Topics 9 07-02-2012 08:18 PM
Dodge Ram K&N 1500 2500 3500 Ramrob Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 16 03-21-2010 11:50 AM
2000 Dodge Ram 1500 Engine Idle up and down on cold start Quiet Lunatic 5.2L V8 Specific Topics 4 01-15-2010 06:30 PM
Meet and Greet In The GTA Scheduled for Saturday October 25, 2008 300 Addict Dodge Ram Forum CANADA 35 10-24-2008 05:23 PM
Meet and Greet In the GTA Scheduled for August 16, 2008 300 Addict Dodge Ram Forum CANADA 20 08-17-2008 02:15 AM
