Old 08-23-2011, 12:07 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
So if you were to remove the cam, would the rocker then just be loose and you could remove it just by picking it up? This would also mean that there is no way to adjust lash right? Unless you shim the lifter? Thanks for the info this helps me a lot(I've never looked at an OHC head).
Sean
Old 08-23-2011, 12:33 PM
SuperiorStyles's Avatar
SuperiorStyles SuperiorStyles is offline
Vehicle: 2002 Dodge RAM 4.8L 290ci
Trim Level: Quad Cab SLT
Rep:12
SuperiorStyles is on a distinguished road
Send a message via AIM to SuperiorStyles Send a message via Yahoo to SuperiorStyles
yea removing the cam will just let the rocker arm sit there and you can't adjust lash. like you said shim the lifter would be one way the other way is to buy some h.o cams that will give you more horsepower and lift and you can keep all the stock components that will give you the back lash you need.
Old 08-23-2011, 12:37 PM
snrusnak's Avatar
Rep:1385
Thanks, I guess I should have asked, I assume the 2nd gen 4.7L (2008+) are the same design right?
Reps for the help!
Sean
Old 08-23-2011, 12:43 PM
Rep:12
yeah 2002 to early 2008. Mid year is when they started new design. as long as you have one coil per cylinder. The new design has 2 coils per cylinder
Old 08-23-2011, 12:50 PM
snrusnak's Avatar
Rep:1385
I have a 2010, so I guess it's different...? I'd assume it's similar, but I think they changed the port design a little. Like I said though I assume the operation of the cam/rocker/lifter/valves is similar.
Sean
Old 08-23-2011, 12:56 PM
Drake371's Avatar
Drake371 Drake371 is offline
Vehicle: 2008 Dodge Ram 1500
Rep:83
Drake371 will become famous soon enough
If I ever get to the point of chanigng out my valve covers , think it be worth it to go ahead and upgrad to h.o. cmas at the same time?
I have to go check to see how many coil packs I have...
Superchips Cortex, K&N CAI 63-1529, Sprayed in Bedliner, ARE cover, Flowmaster exhaust kit ... more to come
Rep:12
ok i looked it up on my alldata
Old 08-23-2011, 01:01 PM
Rep:12
1999-2007 4.7L H.O cams are interchangeable. 2008-UP 4.7L H.O cams will NOT fit older style heads. In 2008 the 4.7L received new IMPROVED heads and cams specific to the 2008-Up heads.
Old 08-23-2011, 01:02 PM
Drake371's Avatar
Rep:83
ahh thanks for the info on that topic
Old 08-26-2011, 08:59 PM
Rep:12
Update: My truck 4.7 Engine is Fully Rebuild New ..020 Flat Top Pistons New Multi Layer Head Gasket Brand New Heads. Ended finding out that i had a Hole in the Intake Manifold from a Backfire the day the Engine Blew a hole the the head so i Replace it with a H.O Intake Manifold. I installed new Map, IAT sensor, Crank sensor , Cam sensor, 180 Thermostat, New Water pump, Bearings, Radiator and installed the Electric Fan Conversion. I got alot to list you all get my drift on what i done. Thank you guys for checking in and keeping up to date on the build. If you have any questions let me know.
How often do we pay extra for things and not even know we did? ArmyofOne Dodge Ram General Discussion 1 06-01-2011 02:08 AM
