Old 09-08-2011, 08:17 PM
Drake371's Avatar
Drake371 Drake371 is offline
Vehicle: 2008 Dodge Ram 1500
Rep:83
Drake371 will become famous soon enough
imageshack.com is a good place to host them and then jsut copy and past the url to each one
Superchips Cortex, K&N CAI 63-1529, Sprayed in Bedliner, ARE cover, Flowmaster exhaust kit ... more to come
Old 09-08-2011, 09:34 PM
SuperiorStyles's Avatar
SuperiorStyles SuperiorStyles is offline
Vehicle: 2002 Dodge RAM 4.8L 290ci
Trim Level: Quad Cab SLT
Rep:12
SuperiorStyles is on a distinguished road
Send a message via AIM to SuperiorStyles Send a message via Yahoo to SuperiorStyles
oh ok Ill do that tomorrow then. Thank you
Old 09-09-2011, 06:28 AM
Rep:12
Update :
http://imageshack.us/photo/my-images...yclean001.jpg/
http://imageshack.us/photo/my-images...yclean009.jpg/
http://imageshack.us/photo/my-images...ture003ov.jpg/
http://imageshack.us/photo/my-images...ture004sq.jpg/
http://imageshack.us/photo/my-images...yclean004.jpg/
Old 09-09-2011, 07:52 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Nice and clean! Looks like a nice efan setup as well....what intake is that? Is that a universal cut and fit one?
Sean
Old 09-09-2011, 02:09 PM
Rep:12
Thanks, The Intake is a AFE stage 2 Set up with a 72 mm throttle body
Old 09-09-2011, 02:11 PM
snrusnak's Avatar
Rep:1385
What all did you change with the new build performance wise? From the few changes I've seen you post I'm sure you noticed a big difference?
Sean
Old 09-09-2011, 02:36 PM
Rep:12
well with the Rebuild instead of going .020 on the piston i went with .030 and I port and polished the heads also went with better Springs and Valve seats to improve the OEM design that caused the problem the 1st time. Also I went with a Cosmetic Multilayer Gasket and copper Exhaust gaskets to prevent leaks that are common on 4.7. I installed an 180 degree thermostat to give the truck better cooling. The Difference I feel is completely out of this world. I barely touch the throttle and it's moving. If I don't keep my eyes on the speedometer I hit 60 in seconds with a light tap of the throttle. Before with the engine bad I used to have to fill up every 5 days now I have been on a tank for 1 week and 3 days and I'm still half and I have been doing city miles. Since the day i Finished the rebuild to now I traveled 274.2 miles so performance is great and mileage is great and all the upgrades are working great. With my intake all you hear is a pure suction and loud too. People are asking if i have a supercharger from the way it sound and the slight whistle it does while it close. My Temp before was 203 to 205 degrees and now with the Electric Fan and the 180 Thermostat its always at 183 to 185. so everything has been solved. Air Fuel mixture is perfect 14.5 to 16 at idle and cruise and 11.5 at full throttle.
Old 09-09-2011, 02:39 PM
snrusnak's Avatar
Rep:1385
That's great! reps to you for a good build!
Sean
Old 09-09-2011, 02:43 PM
Rep:12
thank you for staying around to find out
Old 09-12-2011, 10:32 AM
svares svares is offline
Vehicle: 2004 Dodge Ram
svares is on a distinguished road
My 4.7 overheated and dropped a valve seat.
Compression test showed which one, rocker arm as off
I pulled the head, used head, new gasket and bolts. $150 plus a water pump and thermostat and im back up and running. 70,000 miles on the motor.
Seems to be most common when overheated
How often do we pay extra for things and not even know we did? ArmyofOne Dodge Ram General Discussion 1 06-01-2011 01:08 AM
