Place your Ad Here!
Old 11-03-2011, 05:21 PM
440Magnum 440Magnum is offline
Vehicle: 2008 Ram 1500
Trim Level: Lone Star
Rep:26
440Magnum is on a distinguished road
Originally Posted by SuperiorStyles View Post
That sounds like a good explanation for someone else in my case it was not.
Maybe not overheating, but I'm convinced the valve seat DID drop first and started everything else going bad.
Valve seats do sometimes drop out of aluminum heads for no dang good reason. Nature of the beast, and why I still prefer iron heads for trucks.
Old 11-03-2011, 05:44 PM
SuperiorStyles's Avatar
SuperiorStyles SuperiorStyles is offline
Vehicle: 2002 Dodge RAM 4.8L 290ci
Trim Level: Quad Cab SLT
Rep:12
SuperiorStyles is on a distinguished road
Send a message via AIM to SuperiorStyles Send a message via Yahoo to SuperiorStyles
Well known fact is that it does drop with a very noticeable knock also you would know when it does a good lack of performance, MPG and so on. Mine started with a light tap and goes away which the valve adjuster bore was cracked clicking back to back my MPG was good and my performance as well, My compression was right on the dot and my Dyno run proved that there was no loss. As the Time passed the valve adjuster failed causing the problem on the weak OEM design of the Cylinder Head. My engine never Overheated and always was taken care of. Not all tap,knocking and failures are caused by the same thing but they all have something in common it needs to be addressed and get fixed asap which is my point in all this I posted.
Old 11-04-2011, 03:36 PM
Rep:26
You might be completely right, but here's why I'm not convinced. If the hydraulic adjuster bore actually failed FIRST as you suggest, then when did the valve seat drop out? Because if the follower bore broke, the the valve didn't ever open again to LET the seat drop out of the head. And I think its pretty unlikely that both events happened on exactly the same turn of the cam. The only way to sort out what happened in those last few milliseconds was that the valve seat dropped, propped the valve open, the valve not returning to its full-seated position let the roller follower move sideways off the lash adjuster, then the cam lobe came around again and smashed the follower while it was sitting half-off the adjuster, breaking out the bore in the head casting with an unnatural side-load on the adjuster.
How would that explain the light tapping you heard other times? I don't know for sure- could be typical 4.7 slow pump-up of the lash adjusters. Could be that the valve seat was able to drop down a millimeter or two but not come all the way out, and then stick firmly back in the head and everything would run fine until the next cool-down cycle.
The other problem I have with the theory that the light tap was the bore beginning to crack: why would it ever STOP the light tapping once that adjuster bore began to crack?
Just food for thought- none of it really matters now. And I agree that persistent tapping probably should be watched for other problems.
One question for you- how did the cylinder walls in your original engine look? I know 150,000 miles is around the "might as well do it all" point, but since people report running these 4.7s out to 300,000 miles or more without even burning oil, I'd expect the bottom end to still look very good.
Old 11-04-2011, 10:58 PM
Rep:12
Good theory but no the Valve seat came off during the Spring and Valve operation when the adjuster got stuck on the broken casting causing the camshaft to push and force the rocker arm into the valve causing the spring to bottom out completely and cracking the spring and bending the valve also causing the the Guide to turn into the valve seat which lead to the seat hanging to be pushed out of its Position. The Tapping in the morning was from the Crack on the adjuster bore due to the aluminum head heating cycle at normal temps the metal expanded and the crank close gap. That was in my case in other people case it could just be leaks in the Exhaust gasket or like you said slow oiling to the adjuster.
The cylinder walls were in perfect condition as for all the rings and bottom end. No signs of the Engine having neglect also no sludge anywhere thanks to the Syn oil.
Bearing had no sign of wear or abuse.
Old 01-10-2013, 08:36 PM
bigmike19956's Avatar
bigmike19956 bigmike19956 is offline
Vehicle: 2002 Dodge Ram 1500
bigmike19956 is on a distinguished road
I had a similar problem recently. At cold start up rocker arm actually fell off at start/idle. Had shop put rocker back on, lasted 250 miles, and happened again.Local machine shop said valve seats drop and hold valve open slightly causing rocker to fall off. Also talked to Dodge tech, and he said the valve seat issue would happen on warm engine, not cold. He advised me to replace lifters. Did this and have a very slight tick on cold start but goes away quickly. Knock on wood this has fixed my issue for now.
Old 01-25-2013, 09:29 PM
Well update folks. I now have the heads off and at the machine shop. The machine shop says they cannot find anything wrong with the heads. Seats are not loose, valve guides are in specs, etc. What else can there be??? The machine shop is saying Dodge says there is a fuel issue on certain cylinders causing lean fuel and heating that cylinder, making the valve stick, and making rocker fall off. That would make sense IF the rocker fell off when the engine is warm. The rocker falls off right after cold start. The new lifters did quiet the tap down to just a few seconds. I am so confused, and so is my mechanic. Also, local Dodge dealer doesn't want to share any advice, they're answer is bring it in and let us look at it.
Old 01-26-2013, 10:19 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
I don't understand why people like chasing ghosts. Not to be a jerk but:
THE LASH ADJUSTERS ARE HYDRAULIC. THEY NEED A LITTLE TIME TO GET PRIMED WITH OIL(KEEP IN MIND THEY ARE AT THE HIGHEST POINT ON THE ENGINE).
Once they are primed the lash closes and the noise goes away. It's really NOT an issue 99.9% of the time.
Sean
Old 01-30-2013, 08:32 AM
Rep:12
Many People have a Issue with the Ticking but the Only solution to getting rid of the Noise is replacing the Valve adjusters. There are no fluids that will help and no oil that will help I tried it all before my head failure. Ever Since I did my valve adjuster I hear no ticking or tap in the morning at all thank god and it's been 2 years. It cheaper to Change them now then wait later when they lock up. It's up to some of you to decide what you want and how fast you wanna solve it.
Old 02-08-2013, 12:29 AM
02Kingstonram's Avatar
02Kingstonram 02Kingstonram is offline
02Kingstonram is on a distinguished road
Default My Ticks are gone!
Try Amsoil Synthetic! Worked for me. And change your PCV valve while your at it!
Old 02-20-2015, 11:57 AM
Gniccum Gniccum is offline
Vehicle: 2010 Dodge Ram 1500 HEMI 4x4
Color: Metallic silver
Rep:21
Gniccum is on a distinguished road
I have a serious tick in the morning on cold start. Goes away once warmed up. Did a compression test due to serious loss of performance, cylinder 3 had bad psi wet and dry reading. Could be blown head gasket, then warped head? Ever since I got this truck it seems to be something almost constantly. I PCS to Fort sill and may and need the truck to get down there. Any inexpensive fixes or advice?
How often do we pay extra for things and not even know we did? ArmyofOne LD RAM - General Discussion 1 06-01-2011 01:08 AM
