Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 07-30-2011, 10:07 PM
mclovin7794's Avatar
mclovin7794 mclovin7794 is offline
Vehicle: 2002 Dodge Ram
Color: Grey
mclovin7794 is on a distinguished road
Default Front Suspension Job
Hello,
I would like to try and replace all/most of the components that make up the front suspension. I have an 02 Ram 1500 V8 4.7 ltr Quad Cab with 123000 miles. Any help would be appreciated (tips, tricks, type/brand parts, etc.). Thanks!
Grab life by the horns.
Old 08-03-2011, 02:41 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Are you having issues? There are many kits out there that are for replacing the bushings. Did one years ago to replace the rubber with nylon. Handling was great afterward.
Old 08-06-2011, 07:54 PM
Color: Grey
Right now, the only major issue is the ball joints. They are shot and need to get fixed. Also, every time I hit a bump or a dip, the truck "groans" and the front end squeaks. I was figuring that if I had to do the ball joints I might as well replace the whole front end. The person who owned the truck before me didn't maintain it too well and it needs a lot of work. Just got to do it one job at a time.
Old 08-07-2011, 12:05 PM
06 BigHorn's Avatar
06 BigHorn 06 BigHorn is offline
Vehicle: 2012 Dodge Ram
Trim Level: Express Quad Cab
Color: Deep Cherry Red
Rep:153
06 BigHorn has a spectacular aura about06 BigHorn has a spectacular aura about
Not sure if the part #'s would be the same for you, here's what I got.
Front lower strut bolt - 6509751-AA
Front lower strut nut - 6504707
Front lower strut / lower control arm bushing - 55366746-AE
It's a truck, not a cream puff
Old 08-10-2011, 06:05 PM
Color: Grey
Are those part numbers for an AutoZone, Napa, local stealer (dealer), or private buyer? Please specify.
Old 08-11-2011, 07:28 PM
06 BigHorn's Avatar
Rep:153
Those are Mopar #'s
Old 08-12-2011, 03:25 PM
AndyXplorer's Avatar
AndyXplorer AndyXplorer is offline
Vehicle: 2006 Dodge Ram 1500
Color: Blue
Rep:39
AndyXplorer is on a distinguished road
The groan is probably your struts, it seems to be a common problem, and i wouldn't replace them with the crappy monroe ones either, i used the Rancho 9000ES, and i've seen some people use the adjustable billsteins. I've just about replaced every part in the front end, and it will take you a good day to do it
Front Driveline Question herc 2011 Dodge Ram Forum 7 04-19-2011 05:35 PM
Squeaking front suspension, turning and bumps Lockard191 Suspension 3 03-25-2011 08:04 PM
Bilstein 5100 / Roadmaster Active Suspension ram1hemi Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 8 08-09-2010 06:57 AM
Front Suspension TerryXn9 Dodge Ram General Discussion 3 02-09-2010 02:36 AM
Noise in front suspension 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 7 12-18-2008 09:59 PM
