Old 07-31-2011, 08:55 PM
Dalton's Avatar
Dalton Dalton is offline
Vehicle: 2005 Dodge Ram Daytona
Trim Level: Daytona
Rep:43
Dalton is on a distinguished road
Default Blower Motor Fix
The blower for my A/C has been giving me problems. Sometimes it would work and sometimes it wouldnt and then it finally just stopped working completely. I checked all of the connections on the bottom of the blower and it still wouldnt work. Then with the key on and the blower knob turned to high i tapped on the bottom of the blower and it started working and has been working fine for 2 days now. So before you go tearing into your dash or taking it in for service you might give this a try.
Old 08-01-2011, 02:38 PM
blackout's Avatar
blackout blackout is offline
Rep:16
blackout is on a distinguished road
true, i give my ram a couple of hard wacks under the steering wheel on the dash, and like magic it starts up again. Then in about a month it will stop and repeat the wacking the dash.
Old 08-01-2011, 10:48 PM
Dalton's Avatar
Trim Level: Daytona
Rep:43
Lol you should probly have that looked at if your wacking it under the steering wheel. Kinda sounds like a short and those can lead to other bad things.
Old 08-23-2011, 02:36 PM
majake01 majake01 is offline
Vehicle: 2003 dodge ram 1500 hemi
majake01 is on a distinguished road
I have had a similar problem. The blower would just turn off as I was driving and then come back on again later. I tried tapping on the blower and that didn't work. I tried different combinations of setting on the knobs. Then one day just by chance I changed the position of the steering wheel and it came on. I then lowered the steering wheel and it went off. So know I turn it on and off with the steering wheel.
Ignition Switch and Fan Blower Problem steelman512 Electrical 13 09-22-2013 08:54 PM
Blower motor problems! Help IM HOT!!! M0PARMGNUM Heating & Cooling 4 05-14-2011 06:13 PM
AC blower problems mcline1968 Heating & Cooling 4 12-22-2010 11:34 AM
2005 Dodge Ram 1500 blower? TroyH04 Heating & Cooling 7 11-27-2010 05:05 PM
Blower motor resistor block SD60F Electrical 3 11-25-2009 06:59 PM
