Old 09-16-2011, 01:36 PM
groberts's Avatar
groberts groberts is offline
Color: Inferno Red
Rep:12
groberts is on a distinguished road
That is awesome, I'm actually looking at putting this same kit on mine. How's the ride? Did you get the anti-sway bar too? And did i hear y'all say that if your running factory tire & wheel size there are no rubbing issues? Cause I am eventually going to switch to some black 20" SRT replica wheels and keep the factory tire size. Sorry for all the questions, got really excited seeing how it looks. haha.
Old 09-26-2011, 05:10 PM
Deathrend Deathrend is offline
Vehicle: 2015 Ram 3500 MC DRW
Color: Maximum Steel
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
Rep:51
Deathrend will become famous soon enough
I'm thinking about doing this also.. Just recently picked up a Sport, seems like it would look pretty good dropped.
2015 Laramie 3500 Mega Cab 4x4 DRW Maximum Steel
Aisin | 4.10 | 5th/Goose Prep | Air Assist | 37,800 GCWR
2013 VW Passat SEL TDI
Old 09-26-2011, 05:31 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
Looks good man!
22"s and lopros next??
Dillon-aka, The Little Kid
Old 09-27-2011, 07:39 AM
stangd1909's Avatar
stangd1909 stangd1909 is offline
Vehicle: 2011 Dodge Ram
Color: Grey
Rep:27
stangd1909 is on a distinguished road
Looks good man.
Old 12-19-2011, 01:29 PM
HemiSwagg's Avatar
HemiSwagg HemiSwagg is offline
Vehicle: 2012 Ram 1500 Express RC
Color: Mineral Gray Metallic
HemiSwagg is on a distinguished road
Originally Posted by stricnine View Post
I have no rubbing with the tires. I recently took the truck into a local shop and had the oem trac bar cut and made adjustable to bring the roll center of the rear axle back in line I also had them shorten my oem sway bar end links to bring the rear sway bar back up. Here's pics:
Is this necessary...or? I just want to understand what all needs to be done and why before I do this to my Express. I plan on adding 22x10 inch wheels as well. What is "roll center" and is it that much off from a 2/4 inch drop?
K&N Panel Filter, Magnaflow Ypipe, Cherry Bomb Muffler, In-cabin air filter mod, 3.92 with LSD, Fastman Standard MOD TB.
Old 12-19-2011, 01:37 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
The suspension has a setup like a panhard bar that locates the axle (driver side to passenger side) so the axle actually does not stay perfectly centered through travel. At oem height, it is centered at stock height, but during travel it will shift (less than 0.5" probably) to one side, then during even more travel it will pull back in. Now that he lowered his truck, it is slightly off center due to changing the suspension's "normal" ride height. IMO for a 2/4 kit or just a 2" rear level kit it's not a concern at all. Even with a lower drop it's probably not a concern but that's MO.
Sean
Old 01-16-2012, 01:48 AM
CaddyRam's Avatar
CaddyRam CaddyRam is offline
Vehicle: 2010 Ram
Trim Level: Slt Big Horn CC
Rep:12
CaddyRam is on a distinguished road
34 1/4 inches up front
35 inches on the nose for the rear
I made sure that I seated all springs properly into the factory rubber...man that sounds funny! lol
Next will be a new billet antenna and exhaust. I am still torn between the Flowmaster 50 HD Catback or welding in a 14" Mufflex. Decisions decisions
Get the Mufflex. And it's bolt in not weld in so if you don't like it it's a simple swap to a different length or back to stock. Love my 18"
Mufflex18,limo tint,DNX 6960w/rearview camera, sirrius satellite,DVD,Nav,radar detector/video camera mount, Damplifier.Ez down tailgate assist,bed extender, LineX,relocated rearwindow switch,custom twin filter air intake,custom front/rear center consoles w10'' Kappa and LED lighting.
18" Magnaflow & KN Drop In Installed websterc 2010 Dodge Ram Forum 31 06-29-2011 10:19 PM
Is this HBS sway bar drop kit installed correctly? jeepinoutwest Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 1 02-07-2011 10:45 PM
McGaughys 2-4 drop installed fuzzycali 2009 Dodge Ram Forum 56 11-07-2010 08:50 PM
Got the GroundForce 2/4 drop installed CdnoilRAM Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 19 06-18-2010 01:16 PM
Thinking about Belltech Drop Spindles TenneSST Dodge Ram SS/T - Indy 14 04-03-2010 10:46 AM
