Old 06-17-2012, 10:16 AM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Ok this is going to sound strange go rent a infrred temp reader cause the sounds of it could be the connection not getting enough ground. I had this issue when I put eng in my s10. So use reader at thermistat houseing to make sure. But it sounds like you don't have a over heat issue or you would have boiled it when you ran it for two hours.
Old 06-17-2012, 10:18 AM
ramfam's Avatar
Trim Level: Base
Rep:21
You might want to replace the plug on temp sensor.
Old 06-24-2012, 08:46 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Double check the thermostat itself. Instead of a 180 they may have given you one with a higher temp and that could explain why it's running hotter than you'd expect it to.
46re problems FIXED...... Ram Tough 5.2L V8 Specific Topics 2 04-30-2011 04:28 AM
Thought I Was A Goner!!!!! Chubby Bruiser Off Topic Discussion 12 04-24-2011 05:35 PM
Crazy thought ?? Chrome wheel mod GTyankee Other Vehicle Discussion 7 03-20-2011 12:48 PM
seat wiring fixed and truck cleaned up Outlaw 2010 Dodge Ram Forum 27 12-24-2010 11:57 PM
01 Ram - Fixed Orifice Tube Location viperdriver60 Heating & Cooling 2 09-28-2010 05:37 PM
