Old 08-18-2011, 08:58 PM
Rumble04's Avatar
Rumble04 Rumble04 is offline
Vehicle: 2004 Dodge Ram
Trim Level: Rumble Bee
Color: Yellow
Rumble04 is on a distinguished road
Default 8-10 rwhp?
Hey everyone, I read somewhere that if you move your intake air temp sensor to a cooler location it will give you up to 10 extra ponies at the wheels, has anyone tried this? if so where is the best place to mount it
Old 08-18-2011, 10:36 PM
TheSatinPumpkin's Avatar
Color: Satin Orange
Rep:627
Sweet. Makes removing the A/C worth it lol.
Old 08-18-2011, 11:17 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
Not sure, but it sounds like you are just tricking the PCM into thinking the motor is getting cooler denser air when it's not. If your IAT readings are lower the PCM will make timing/fuel adjustments for the "new" IAT temps. I doubt it would be enough to cause engine damage but you never know.
I recommend getting a custom 93 octane tune b/c you'll get better gains and if it's from a good tuner it'll be the safer way to go.
Or....maybe the dodge engineers overlooked something and what you're talking about could be a nice cheap trick we can all take advantage of! Anyone else have some thoughts?
Old 08-19-2011, 12:44 AM
robustRed's Avatar
robustRed robustRed is offline
Vehicle: 2008 Dodge Ram 1500
Trim Level: Lone Star PKG
robustRed is on a distinguished road
yeah i have heard of it. forgot what its called but what it is, like a resister put inline with your Air intake sensor wires that basicly does the same thing. OH, hear ya go found it. its called a Power wire. here is a link. dk if it works with the 4th gen tho
2WD-Dsp 93 tune-55 series tires-3.92s-PacesetterLT Headers w/ 3in catted y-pipe- DynoMax Race Bullet- 2.2K ohm power wire- hellwig rear sway bar- 190 Degree Thermostat-
Old 08-19-2011, 01:36 AM
015.9's Avatar
015.9 015.9 is offline
Vehicle: 2001 dodge ram 1500
Trim Level: off road edition
Color: IB
015.9 is on a distinguished road
seems alittle too easy to me....10 RWHP? i doubt that you would even get that much of an increase at the crank from this mod.
Old 08-19-2011, 02:38 AM
jpaul51's Avatar
jpaul51 jpaul51 is offline
Vehicle: 2009 Ram 2500 Megacab
Rep:167
jpaul51 has a spectacular aura aboutjpaul51 has a spectacular aura about
I seriously doubt it adds that kind of power. When I added my BFI intake I also ordered the iat extension wire which allowed me to relocate the sensor to the inside of my Airram Jet stream scoop. So I know it is getting the incoming outside air temp and not the under hood temp. I also used to run the aforementioned power wire and could not tell much of a difference with it either. My next mod to really be able to feel a power increase is to get a cam and dyno tune.
2007 Ram 1500 QC - SOLD and bought a 2009 4x4 Megacab 2500 with 6.7 Cummins. Full Sinister EGR/Throttle Valve/dpf deletes, 4" Turbo back exhaust, Banks cold air intake, EFI Live tuning by Anarchy Diesel running 100hp Street tune. Peragon bed cover.
Old 08-19-2011, 10:21 AM
Rep:1385
The computer needs ACCURATE readings from the sensors to provide appropriate air/fuel ratios. You could put that sensor in an ice box, and it would read cold, but the computer would dump alot more fuel to compensate, and you would get a rich fuel mixture, this won't help power. I always thought this thing was a scam... besides, you would want to lean the mixture to make more power, not richen it...
Old 08-19-2011, 10:53 AM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:561
x2
You're better off to actually cool your engine with a Jet 180º T-Stat than to try and "fool" the computer with a false cool reading.
...and If you want real control of your A/F to maximize performance, get a CMR Tune.
Old 08-19-2011, 11:03 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
"Power Wires" are actually stupid wires! No thanks!
Old 08-19-2011, 11:16 AM
Rep:2705
sort of reminds me off a trick we used to do long ago
we hung desert water bags in front of our radiators, those bags don't seal completely up, so they drip water constantly.
It changes the atmosphere in the engine compartment & there is a definite power increase
it is like driving in a misty rain, without the roads being wet
it worked real good on vehicles before all the computers were put in them
hanging those bags on the front of the radiator originally was done to keep the water chilled
Desert water bags are effective because they effectively keep water cool and appetizing to drink, especially on a hot day in the dry desert. Water kept in canteens will be warm or hot, and definitely won't quench your thirst in the same way. Desert water bags consists of skins that evaporate and cold water to keep the inner body core cool.
Read more: About Desert Water Bags | eHow.com http://www.ehow.com/about_4727523_de...#ixzz1VU5LHwcc
SuperCharged Hemi RAM thanks to Magna Charger azzo540 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 240 11-30-2015 01:19 PM
Trick Flow Harmonic Damper RamTex Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 67 02-18-2011 09:10 PM
Anyone have rwhp numbers? lave80 2009 Dodge Ram Forum 12 12-25-2009 12:39 AM
Dyno- Actual RWHP 2002DodgeRamSport Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 4 10-21-2009 10:20 PM
