Old 08-01-2011, 05:09 PM
DRAM1500's Avatar
DRAM1500 DRAM1500 is offline
Vehicle: 1998 Dodge Ram 1500 4x4 QCSB
Color: RED
Rep:25
DRAM1500 is on a distinguished road
Default Best MPG Gains 13.8 mpg to 23.7 MPG!
I hate oil companies and bought my 5th Dodge Ram, this one is a MINT 98 Ram 4x4 1500 with a 5.9L V8. First 2 tanks I got 13.8MPG & I drive it easy & coast when I can since I live in a small town an hour outside of Toronto.
I have always modified every vehicle I have owned cause of the price of fuel here in Canada. The price of fuel is approx $1.25 Canadian on average, there is 3.78 Litres in a US gallon so it is costing me about $4.66 Canadian per gallon which is about $4.40 USD a gallon and it sucks!!!!!!!!
So my 98 Ram with a 5.9L in it got 13.8MPG to start, I brought it home and here is what I changed to get 23.7 MPG, yes, that is 23.7 MPG from a 5.9L!
Cold Air Intake from eBay $118
TBI Spacer from eBay $ 68
E3 Diamond Fire Plugs $ 70
MSD Coil & Adapter $ 145
MSD Plug Wires $ 120
New Tensioner Pully $ 120
New Serpintine Belt $ 40
Synthetic 0W30 Oil Chg $ 60
Synthetic Diff Oil Change $ 70
Synthetic Tranny Oil Chg $ 50
55 PSI in my 285/75/16s $ 00
Superchips Flashpaq 3865 $400
Remove ALL unwanted Lbs $ 00
I also removed the fan from the motor & replaced to with a custom made alum. shroud where I placed 2 10" elec fans with 180* temp module, total price was $190 for this. I measured the shroud and drew a design of the alum shroud I had cut, bent & welded at the local metal shop & I put the fans on & installed it myself. This is way cheaper than the ones available for $500+ online
I also put on Tonneau Cover which has been shown to give better MPG
The last couple things I have to do is install High Grade GMB wheel bearings packed with the best synthetic grease. Topped off with drilled & slotted rotors. Price of this should be about $300
So for approx $2000 you can up your MPG by a huge amount, even if you are using tires bigger than 285's
I am going to try one tank in a week or two and going to HyperMile it & will post what MPG I get, hope to get 30-35MPG!
Anyone else with any other MPG improvements??????????????
Old 08-01-2011, 05:24 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
That is an outstanding MPG improvement
Dillon-aka, The Little Kid
Old 08-01-2011, 09:05 PM
Jd3443pd Jd3443pd is offline
Vehicle: 1998 Dodge Ram SS/T
Color: White W/Blue Stripes
Jd3443pd is on a distinguished road
Very impressive feat you have accomplished.
Old 08-01-2011, 09:13 PM
pkr11 pkr11 is offline
Vehicle: 2006 Dodge Ram 1500 SLT
pkr11 is on a distinguished road
Very nice improvement
Old 08-01-2011, 11:25 PM
DRAM1500's Avatar
Color: RED
Rep:25
Default Injectors
I am thinking of putting new 4 hole Bosch injectors in to replace the one hole Siemens injectors. I don't know if it will give me anymore MPG, I know it should run better and most likely give me a little more HP, but does anyone know if this would improve MPG?
I am thinking it should be giving more HP, a better burn thru atomization so I am thinking it should help MPG, slightly, any thoughts?
Old 08-02-2011, 01:27 PM
ramoreno's Avatar
ramoreno ramoreno is offline
Vehicle: 2002 Dodge Ram
ramoreno is on a distinguished road
OMG, thats awezome, i think you get better mpg than my nissan altima
Old 08-02-2011, 02:04 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Wow not to say I don't believe this or anything, but I don't believe you, lol! That's a 70% increase! ...I'd need proof sorry, that's just a little too much for me to take, lol. Especially the 30+, that's over 100% increase!
Sean
Old 08-02-2011, 02:06 PM
snrusnak's Avatar
Rep:1385
Oh and since you asked, I went from about 16-17 avg to about 17-18 avg (almost all city) with the superchips on 91 tune. I think it was better slightly on the 93 tune but I had some pinging. I can get like 22-23mpg on the highway at 65-70mph. 20mpg at 75-80 is piece of cake.
Sean
Old 08-04-2011, 03:52 AM
dodgeram02's Avatar
dodgeram02 dodgeram02 is offline
Vehicle: 2011 Dodge Ram 1500 Quad Cab
Rep:59
dodgeram02 will become famous soon enough
i can believe that. i get 20 to 24 on the highway with a cold air intake, throttle body spacer, and throttle body mod, superchip programmer, msd ignition, msd 8.5mm wires and 180 degree thermostat, and bosch platinum 4 plugs.( i was told these actually kill my mileage, and to go back to a copper plug, but at $50 for the set, they will last for a few miles. where did u get the fans and how did u wire them up? i been really thinking about doing this, but not sure how i could wire it up, so it would kick on at a certain temp. and turn off at a certain temp. any help would be great.
"I dont lie to my wife about my truck...I dont lie to my truck about my wife, they both know, no matter how good they treat me I'm still going to get on the other one"
Old 08-04-2011, 09:05 AM
polarihog's Avatar
polarihog polarihog is offline
Vehicle: 2011 Dodge Laramie 4X4
Color: Black Metalic/ Gray bottom
polarihog is on a distinguished road
Send a message via Skype™ to polarihog
wow..this sure beats the hell out of my 5.7 hemi.. I get 13 on average and 19 on the highway with cruise set at 110km/
MPG or HP or other gains 2001RAMSPORT Fuel System 3 02-02-2011 07:37 PM
