Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
tonneaucovered.com
Old 08-02-2011, 02:11 AM
DavidNC DavidNC is offline
Vehicle: 2005 RAM Quad HEMI 4x4
Trim Level: Thunder Road
DavidNC is on a distinguished road
Default Odometer reset required
I need to have my odometer reset for legal reasons.
I just bought a truck that had a used cluster installed, showing less mileage, to correct a door lock issue. In NC, I'm required to either have the odometer set to match original or reset to zero with a sticker added to the jamb.
In my case, the title work won't be completed until the bank retrieves the title. So I have a few days to figure this out. It has 176K actual miles, but now shows 138K. The cluster was changed last week and I have the original cluster to work with.
Can a module be taken off the back of the original cluster and swapped into the replacement cluster to show original mileage?
If required, I can reinstall the original cluster for inspection and title mileage purposes and try again later.
Thanks
Old 08-02-2011, 09:52 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
If you take it to the dealer, they have the scan tools that are needed to do this. Swapping of modules (to the best of my knowledge) is not an option.
brad
Interested in one of my mods?
Old 08-04-2011, 11:26 AM
In hopes that this helps others, I will give my cluster swap observations. To get time, I swapped the original cluster back in for inspection and will wait, until lien free title is processed, to swap back the new cluster back in.
The swapped in replacement cluster had wrong mileage and remotes did not work. I noticed a black box attached to the back of the cluster. The 2005 service manual states that this is the RKE (remote Keyless Entry) module, which is removable. When swapping a cluster, moving the original RKE to the "new" cluster may keep remotes working. Or, is the RKE the problem? Doubt it since the manual lock/unlock and low speed auto lock now works.
With original cluster back in, remote and door switches lock/unlock intermittently. Low speed auto lock does not work. Horn always beeps when lock pressed.
Old 08-04-2011, 11:51 AM
highlandchef's Avatar
Conventional Eccentric
Trim Level: SLT Big Horn
Rep:220
Once you get the title and you swap to the new cluster you may need have the title change to show the discrepancy. Check with the DMV as it depends on the state.
Old 08-09-2011, 10:52 AM
In NC, the law gives three options:
1. Have replacement odometer reset to match accurate mileage. I believe dealer has to do this.
2. Have replacement odometer set to zero and place a sticker on the driver's door with mileage and date at time of swap. This can cause carfax issues if mileage is less than previous time recorded. I believe dealer has to do this, so why not set it to coorect mileage?
3. Just leave it and indicate on title that the odometer reading cannot be reliied on. probably a good idea to document mileage on old and replacement clusters and date at time of swap.
In reality, most people and garages arund here don't do any of the three. They swap out the cluster, usually document the swap, and not make reference to the inaccurate odometer reading on the title.
Old 08-20-2011, 06:17 PM
I decided to try a new key fob before switching out the cluster. A buddy gave me his old fob to try, and it worked. Unlocks on the first try, and locks after about twenty seconds wait when unlocked.
This may be normal, but my truck will not allow the lock to work for about twenty seconds after the doors have been unlocked. Neither the fob or interior switches will work.
Odometer Reset Dieselkiss 5.2L V8 Specific Topics 15 08-02-2011 02:02 AM
Oil Monitor Reset Question Mr. Ed Cummins Diesel Specific Topics 4 10-03-2010 07:20 PM
Parttime Speedo Dragonslayer Electrical 8 09-08-2010 10:43 PM
Adaptive learning table reset, yes or no? GPSHSLAX Dodge Ram General Discussion 16 07-14-2010 03:07 AM
Odometer question Dieselkiss Body & Interior 3 03-01-2010 07:12 PM
