6" lift warranty question - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-02-2011, 10:03 PM
RFarruggia's Avatar
RFarruggia RFarruggia is offline
Vehicle: 2010 dodge Ram 1500 ST
Color: Black Metallic
Rep:17
RFarruggia is on a distinguished road
Default 6" lift warranty question
If i was to buy a 6" lift with 35' tires, would this void my suspension warranty? Or better yet void anything? im saving up and i want to go higher so this is deffinately a possibility. otherwise i will have to just put 33" tires and go with a cold air intake along with exhaust etc... any help will be greatly appreciated
5.7HEMI 4x4 Leveling Kit 8K HIDs 20%Tint Front 5%Tint Rear Trailer Break Remote Start Tonneau Cover
Old 08-02-2011, 11:37 PM
Yes, Dodge will not warranty your suspension nor any bearings at the transmission, differential, any intermediate driveshaft bearing, etc...
Old 08-03-2011, 09:07 AM
RFarruggia's Avatar
Rep:17
Good to know thanks at least I know now to wait until my warranty's up to lift my truck...I will probably just put 33s on there and do some little things
Old 08-03-2011, 09:15 AM
E.L.D. 44's Avatar
E.L.D. 44 E.L.D. 44 is offline
Vehicle: 2011 Dodge Ram CC 4x4 Sport
Rep:388
E.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really niceE.L.D. 44 is just really nice
You could shell out for the Mopar 4" lift if you really wanted it right now! Some dealers will still honor the warranty even though they don't have to. I would ask you dealer the same question. The worst you can hear is no...
MY MOD THREAD
http://www.ramforumz.com/showthread.php?t=87541
Old 08-03-2011, 10:17 AM
Pud1309's Avatar
Pud1309 Pud1309 is offline
Vehicle: 2010 Dodge Ram 1500 TRX4
Trim Level: TRX4
Rep:57
Pud1309 will become famous soon enough
I think it vary's, sometimes your dealership will have the final say, they told me they"ll warranty up to a 4" lift, doesn't have to be mopar, but they must install it (aka they wants there 40/hour garage rate haha)
Old 08-03-2011, 01:01 PM
Upstater's Avatar
Upstater Upstater is offline
Vehicle: 2010 Dodge Ram Hemi SLT 4x4
Trim Level: Bighorn
Color: Stone White
Rep:132
Upstater will become famous soon enoughUpstater will become famous soon enough
This isn't totally correct. The only parts most dealers won't cover are the aftermarket parts. In my case I talked to the dealer before installing my lift and they have no problem honoring the warranty on factory parts. Also, if I'm not mistaken there's a law on the books that prevents them from simply not honoring a warranty because of aftermarket parts.
Old 08-03-2011, 03:32 PM
BS...If you wear out a bearing because your pinion angle is over spec due to your aftermarket lift kit, forget about getting warranty on that OEM part.
The Magnusson-Moss Act is what you are referring to. Basically, it outlines the duties and the rights of the buyer and seller with respects to warranty. It also provides for ajudication/arbitration and other forms of settlement when a dispute arises.
Dodge is perfectly within their rights to disclaim warranty coverage for an OEM part that fails due to a modification.
The difference is they can't disclaim warranty for an OEM part that is not associated nor was the failure caused by the modification.
To illustrate: You lift your truck and your radio head unit quits. You have warranty on your head unit.
Certainly, the burden of proof that an item should be warranted is on the buyer and equally the burden of proof that an item cannot be warranted due to the buyer's actions is on the seller.
You are correct that they cannot simply void your warranty because you have mods. And they are not obligated to warrant aftermarket parts.
But if the mod contributed to the OEM part failure, that's pretty much it as far as collecting on the warranty.
Old 08-03-2011, 06:49 PM
Upstater's Avatar
Trim Level: Bighorn
Color: Stone White
Rep:132
No BS, but believe what you want. When I had my '07 Ram I put a leveling kit on it and trashed the CV joints in 6 months. My service adviser told me point blank they knew it was from the kit, but they replaced the CV joints under warranty, no problem.
Old 08-03-2011, 06:58 PM
Sledneck's Avatar
Sledneck Sledneck is offline
Vehicle: 1998 Dodge Ram Club Cab 2 Door
Color: Midnight Blue
Sledneck is on a distinguished road
I would just wait for lift and tires why void warranty? Its like throwing thousands of dollars in a fire?
Old 08-03-2011, 07:40 PM
Pud1309's Avatar
Trim Level: TRX4
Rep:57
or go my route, leveling kit and body lift, similer look and keep your warranty
Question on warranty for US truck in Canada mtgcards Dodge Ram Warranty Issues 3 02-06-2013 10:19 PM
99 2500 4x4 Lift Question roadwarrior86 Newbie Checkin! 10 03-16-2011 11:37 PM
Question on Lift and Tires alfredenewman Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 03-14-2011 09:49 PM
Question on lift kits black beauty Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 01-12-2010 04:34 PM
question about lift kits and warranty beachbummer0069 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 1 03-22-2009 08:57 PM
