Old 05-24-2012, 08:33 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
I was just getting ready to write that, but I think the hp gain was still after those mods
Old 05-24-2012, 09:50 PM
irnwkrkev irnwkrkev is offline
Vehicle: 2011
Trim Level: Longhorn
irnwkrkev is on a distinguished road
Don't forget if going to a cam as large as the 274 you're going to need :
valve springs
stiffer pushrods
non-MDS lifters
MDS solenoid plugs
The 6.4 has different :
MDS lifters ($400 at a discount parts house)
Springs ($100+)
The 6.4 has the SAME:
timing chain
spring retainers and locks
pushrods
rocker arms
Anyone know if the head bolts are TTY (torque to yeild)? That would require new bolts.
Old 05-24-2012, 10:06 PM
916Timmy's Avatar
Rep:1443
The cam goes in with no additional mods
Old 05-24-2012, 11:06 PM
ericlee9386's Avatar
ericlee9386 ericlee9386 is offline
Vehicle: 2011 Dodge Ram
Rep:36
ericlee9386 is on a distinguished road
Would it even be safe to spin this motor to 6500+ with stock springs. It seems to me that like the 273 for the third gen's maybe the 274 isnt made for us quad cab guys
Performance mods
2800 stall, moes ported throttle body, vararam intake, ARH LT, Flowmaster 10 series, Hemifever tune.
Best 1/4 mile: 14.30 @91 mph soon to be 13's
Old 05-24-2012, 11:55 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
valve springs
stiffer pushrods
non-MDS lifters
MDS solenoid plugs
Springs ($100+)
timing chain
pushrods
rocker arms
Why do you "need" non mds lifters? And the MDS plugs for these motors are a no no.... If one was to put this cam in a motor then they would have a diablo tuner which allows you to disable mds no need for plugs or new lifters...
One thing that you would also need is a cam phase limiter from comp cams. Without a cam phase limiter you will surely see piston to valve clearance issues!
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 05-25-2012, 12:25 AM
916Timmy's Avatar
Rep:1443
The 266 cam sounds like money for trucks! I am still wanting the 6.4 cam.....60 bucks vs 811!
Old 05-25-2012, 06:18 AM
Vehicle: 2011
In the ls world the lifter for the auto cars can not take the spring pressures needed to control the valvetrain of most aftermarket cams. It is necessary to swap in non-DOD (gm's MDS) lifters. The high spring pressures can cause the lifters to colapse.
Check out the specs for a stock cam and the 6.4 cam.
sprintertech
6.4 with mds......
Total duration....
Intake 286 open@36*btdc/closes@250*atdc
exhaust 288 open@278*btdc/closes@10*atdc
46 deg overlap
lift@valve w/0lash
intake .577
exhaust .537
09+ truck 5.7 with mds
total duration
intake 268....opens@28.2*/closes@239.8*
exhaust 290....opens@274.2*/closes@15.8*
44*overlap
lift@valve w/0lash
intake .472
exhaust .460
.105" more lift on the intake and .067" more lift on the exhaust with the 6.4 vs 5.7. I'd like to know how much "cushion" there is untill spring bind with the stock cam. Another question is the amount of lift a 5.7 MDS lifter can take and still be functional. .105" is a lot of lift!
Maybe the 6.4 cam can be used with MDS shut off with the stock MDS lifters. But why use an MDS cam then?
Obviously by the different part #'s Dodge felt that to run the 6.4 cam they needed new lifters and springs. Seems to me they re-used as much as they could, since all the other parts I listed have the same part #'s.
The comp VVT cams are designed to retain VVT, not MDS. That is why I mentioned solenoid plugs and standart lifter swaps. If you think you'd be able to use the stock springs with the 274 cam you're crazy!
Old 05-25-2012, 08:49 AM
916Timmy's Avatar
Rep:1443
The stock 6.4 has MDS and the same valve springs. I would probably put beehive springs in just to be safe, but as far as Comp goes, it's not necessary.
Old 05-25-2012, 02:38 PM
Vehicle: 2011
I'd like to know WHERE you found out that the 6.4 and 5.7 use the same springs. I've searched through factory parts dealers websites and they are listed with different factory part numbers.
The comp cams have more lift then then the 6.4 cam so how would they not require different springs? A spring for .470" lift is certainly NOT going to work with .6++" lift!
I swapped a ls9 cam in my ls3 camaro because it was non-dod, non-vvt, and similar in lift to the stock ls3 cam....just a little bit more duration. It was good for 20hp. The car only had 800 miles on it and didn't even require gaskets.
If you try put a comp .6++ lift cam with stock lifters (w/out tuning out mds) and stock springs you will surely toast your motor! I'd like you to even find a mechanic who will tell you they'll do it for you. You obviously can't do it yourself or you would know better!
Old 05-25-2012, 04:04 PM
916Timmy's Avatar
Rep:1443
Thats how HHP did it, and if they say it's cool and Comp says its cool, then it probably is Done arguing!
how to cam swap hemi moparmike07 Dodge Ram Knowledge Base 5 04-11-2013 11:17 PM
Arrington cam write up...4th Gen CHVYKLR Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 17 10-23-2011 01:21 PM
Front CAM Finally Installed. RansRAM Custom Dodge Ram Interior Modifications - Custom Audio / Video 38 09-27-2011 09:55 PM
new cam for mega cab? ohmega07 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 2 02-23-2011 12:30 PM
Custom Cam heavyfoot33 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 10 05-22-2010 04:01 PM
