Old 05-29-2012, 10:17 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Looks like some better valve springs, lifters and pushrods. It looks like the high lift will have to be run with MDS disabled. Thanks irnwkrkev for setting me straight! HHP has a Challenger with a 274 Comp VVT cam, PSI springs, non mds lifters. They are also working on the locators and better pushrods.
Old 05-30-2012, 06:54 AM
AirborneSilva AirborneSilva is offline
Vehicle: 2013 Ram Sport
Rep:74
AirborneSilva will become famous soon enough
Originally Posted by js1977 View Post
I want this !!!!!!!!!! I don't care what needs to be added or not, a better cam adding up to 100hp is something I want to be part of, now I just need to save up the money , lol....
Not sure how you're planning on tuning those mods since there is not tuner for 2011 up.... Just a thought
2013 Ram Sport
1976 Corvette L82
Old 05-30-2012, 09:57 AM
garner's Avatar
garner garner is offline
Trim Level: Lonestar
Rep:46
He could do a 09-10 ecu swap from B&G
Gone but not forgotten:
First 2011 Ram R/T in Texas
Old 05-30-2012, 10:21 AM
Rep:74
WOW, what a headache and expense, hopefully they will crack this soon....
2013 Ram Sport
1976 Corvette L82
Old 05-30-2012, 07:13 PM
916Timmy's Avatar
Rep:1443
It is definately not ideal, but it is better than nothing....for now
Old 05-30-2012, 07:22 PM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
x2. One must do what one can.
Old 06-25-2012, 01:16 PM
Tpabayflyer Tpabayflyer is offline
Vehicle: 09 GC
Trim Level: Limited
Tpabayflyer is on a distinguished road
Originally Posted by sprintertech View Post
wow so no ones heard of anyone whos attempted this....interesting!
really wish some else could be the pioneer here....lol
Well, I have the 6.4 cam and going to get the comp cams phaser and a set of 6.1 springs as well. Springs are good for .580 lift. The 6.4 apache heads may have longer valves and use different springs so the 6.1 springs should be the ones to use on the eagle heads as this has been proven to work just fine.
I already have a predator tuner so I will have to research getting a tune. Lifters,pushrods, should be all compatible. My 09 Grand Cherokee has most of the normal bolt on mods and I do have the srt8 headers and complete exhaust as well. The stock cam is very mild and really works well for an all around engine that can be used for towing. I bet this 6.4 cam will really wake this engine up big time and allow those big intake ports to do the job they were designed to do! I don't have any dyno numbers but I have run a 14.18 a 98mph in the 1/4 so that is my baseline..............
I plan on doing this cam swap in a couple weeks leaving the heads on. I need to fab up or get a on the head valve spring compressor to change the springs using compressed air. I will check back when I get this project going...... TBF
Old 06-25-2012, 06:23 PM
irnwkrkev irnwkrkev is offline
Vehicle: 2014 Ram
Trim Level: Longhorn
irnwkrkev is on a distinguished road
Thinking about the added lift from the 6.4 cam for the MDS lifters isn't quite as much as I thought being that it is pre rocker arms (1.7:1 ratio I believe). It still makes me wonder though as to why they would specify a different part number for the lifters when they seem to have used the same parts on the 6.4 as the 5.7 as often as possible.
Old 06-25-2012, 06:42 PM
ericlee9386's Avatar
ericlee9386 ericlee9386 is offline
Vehicle: 2011 Dodge Ram
Rep:36
ericlee9386 is on a distinguished road
How hard would the tuning be to add the 6.4 cam
Performance mods
2800 stall, moes ported throttle body, vararam intake, ARH LT, Flowmaster 10 series, Hemifever tune.
Best 1/4 mile: 14.30 @91 mph soon to be 13's
Old 06-25-2012, 07:25 PM
Vehicle: 2014 Ram
B&G advertise that their tuning can include mild cams. I imagine they could handle it with one of their tunes. A little data logging with a wide band and some fine tuning would make it perfect but the down time is a bummer.
how to cam swap hemi moparmike07 Dodge Ram Knowledge Base 5 04-11-2013 10:17 PM
Arrington cam write up...4th Gen CHVYKLR Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 17 10-23-2011 12:21 PM
Front CAM Finally Installed. RansRAM Custom Dodge Ram Interior Modifications - Custom Audio / Video 38 09-27-2011 08:55 PM
new cam for mega cab? ohmega07 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 2 02-23-2011 12:30 PM
Custom Cam heavyfoot33 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 10 05-22-2010 03:01 PM
