Old 08-07-2012, 01:39 PM
sprintertech's Avatar
sprintertech sprintertech is offline
Vehicle: 2010 RAM
Trim Level: BIG HORN
Color: AUSTIN TAN
Rep:16
sprintertech is on a distinguished road
Originally Posted by 916Timmy View Post
I wouldn't have put it in without the phaser after Sprintertech checked the ptv clearances
i was actually lied to by one of the tech advisors who stated that the valves would contact the pistons with the 6.4 cam......
CMR TUNED(tweeked),K&N DROP IN, MODDED AIR BOX, NITROUS EXPRESS 150 SHOT, ARH 1 7/8 LONG TUBES NO CATS, BORLA XR-1, PRO TORQUE 2800 STALL, 4.56 GEARS, MOPAR LSD, ADJUSTABLE REAR LOWER CONTROL ARMS RELOCATED UNDER AXLE, GREDDY CATCH CAN, STICK PEOPLE IN REAR WINDOW......12.97@108...SOLD
Old 08-07-2012, 04:55 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
So no on the phasers???? I just have to figure out what to do for springs. Apparently, the 6.1 springs need to be shimmed and the 6.4 springs are too tall. I might just buy some PWR heads and call it good
What is the plan now SprinterTech?
Old 08-07-2012, 04:59 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
^Shims are no big deal. Any springs should be checked and shimmed as necessary, anyway for best performance... Head castings aren't PERFECT.
Sean
Old 08-07-2012, 05:12 PM
916Timmy's Avatar
Rep:1443
Yeah, but I don't know what the spring height is and how much shimming it would take....On a positive note....
MDS confirmed to work. He only changed the springs and cam.....Worked fine! In a 2011 nontheless!
Old 08-09-2012, 05:56 AM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
I wonder what power gain this was worth. Does it add any sort of "hey I'm cammed" lope?
I need more power and not being able to tune these bastards is killin me
2011 Big Horn 4x4 -SnowWhite-
Old 08-13-2012, 01:11 PM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
This guy Josh on the other forum has a 2005 Ram, and his heads have shorter valve lengths than the 09's "and" make less hp. If it were posible to swap your heads out to these older heads then maybe you can do the swap in your 4'th gen Rams without clearance issues. But then you would be loosing hp with the head swap and gaining how much if any at all? I am not positive if the cam swap will work or not but I still don't think so. I am just trying to help prevent a catastrophe. I got some feed back from someone who just recently designed a set of badd ass heads (2X stronger than oem)for these things and this is what he said. Of the stock heads the 09 has the longest @ 5.175/5.125, 6.4 @5.135/5.100 and 03-08 @4.980 intakes but with different exh lengths of 4.950 and 4.925 and he doesn't seem to think it will not work either. I'm not trying to crash the party, just sharing my opp, thx
Old 08-13-2012, 01:19 PM
snrusnak's Avatar
Rep:1385
^Josh actually has a 2011, his screen name is deceiving...
Sean
Old 08-13-2012, 01:25 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 08-13-2012, 02:20 PM
RadioFlyer's Avatar
Rep:146
Are we talking about blownhemiram05? And Ramtex, could you please explain your video and build, thx.
Old 08-13-2012, 02:23 PM
snrusnak's Avatar
Rep:1385
I thought they were talking about Josh, fasthemiram05(IIRC that's his screen name) who put a 6.4 cam in his 2011 5.7L. The videos ramtex posted are of Josh's truck. I think the 12.4 video is before the cam because he ran a 12.4 when I was there with him before the cam. He has jeep long tube headers(don't remember which brand), 6.4 cam now, nitrous(ran 175hp shot when I was with him), an RT converter, and I think intake/muffler and that's it I believe...oh and B&G tune and slicks and I think some small things like 180 deg tstat and mech fan delete(v6 efan). 3.55 lsd.
Sean
how to cam swap hemi moparmike07 Dodge Ram Knowledge Base 5 04-11-2013 10:17 PM
Arrington cam write up...4th Gen CHVYKLR Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 17 10-23-2011 12:21 PM
Front CAM Finally Installed. RansRAM Custom Dodge Ram Interior Modifications - Custom Audio / Video 38 09-27-2011 08:55 PM
new cam for mega cab? ohmega07 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 2 02-23-2011 11:30 AM
Custom Cam heavyfoot33 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 10 05-22-2010 03:01 PM
