Old 03-21-2013, 11:48 PM
ratbastard ratbastard is offline
Vehicle: 2011 R/T - Ram
Color: Charcoal
ratbastard is on a distinguished road
I ordered the 6.4 SRT cam today... Up here in Canada it is just over $100 bucks. I am planning on doing the swap in about 2 weeks. I am doing the cam, headers, intake, e fan etc all at the same time... sadly we got 10" of snow today!! So spring is a little ways away yet..
I have a toasted 2010 5.7 that i am going to take the valve covers off and rotate to see how much room is left over to allow for the extra lift from the SRT cam. there is only about a 3 - 4 mm difference, So my mechanic thinks that we do not require new springs.. or new pushrods. I just want to make sure that with the new cam the springs do not bottom out... so I will know this weekend.
I will take pics and post them along with my results. I am doing everything at once so i will not be able to tell how much just the Cam swap would help.. But.. I am going to do a before and after dyno test..... so that should be interesting..
stay gold pony boy.
m
Old 03-22-2013, 07:56 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
More importantly, you need to check piston to valve clearance.
Sean
Old 05-28-2013, 03:01 PM
JB2012ram1500 JB2012ram1500 is offline
Vehicle: 2012 dodge ram
Trim Level: Outdoorsman
Color: 2 tone black and grey
JB2012ram1500 is on a distinguished road
from what i have been reading you will need new springs that might need to be shimmed p# 5037382BC these are the 6.4 springs but you do not need new push rods the 5.7 measure the same. thats what i have been reading but apparently there are 2 different cams for the 6.4s
p# 5038419AB this one for the mds.
p# 5037379BC this one with out mds
HBS 2.5 leveling kit, k&n cold air intake, bt catch can, possible exhuast... maybe a tuner
Old 05-28-2013, 03:15 PM
snrusnak's Avatar
Rep:1385
Seems like a lot of work/time/money for such little hp gain...if there even is a gain. I haven't seen anyone that really has any hard evidence that there is a big gain.
Sean
Old 05-28-2013, 04:51 PM
ericlee9386's Avatar
ericlee9386 ericlee9386 is offline
Vehicle: 2011 Dodge Ram
Rep:36
ericlee9386 is on a distinguished road
I have to agree. Without proper gearing, stall, and spinning pass 5950 you won't get the full potential.
Performance mods
2800 stall, moes ported throttle body, vararam intake, ARH LT, Flowmaster 10 series, Hemifever tune.
Best 1/4 mile: 14.30 @91 mph soon to be 13's
Old 05-28-2013, 05:27 PM
Rep:36
6.4 springs don't fit. Manley are direct replacements no shims needed.
Performance mods
Old 05-28-2013, 10:13 PM
okay awesome thanks for the info
Old 05-29-2013, 07:42 AM
Thet's Avatar
Thet Thet is offline
Vehicle: 2013 Dodge Ram
Color: Gray
Rep:32
Thet is on a distinguished road
Does anyone know approx. the HP gains you get from this? And will gains only be seen in the upper RPM range?
Old 05-29-2013, 10:10 AM
catsltd catsltd is offline
Vehicle: 2010 RCLB SLT 1500 Ram
Color: Mineral Gray
Rep:72
catsltd will become famous soon enough
You cannot use the stock springs.
PSI 1511 or Manley are the only options for reliability.
Both install around 1.8 inches.
PSI install at 1.8 inches,
Manley 1.81 with no shimms needed.
I dont think the PSI would need much shimming,especially if you used the stock spring cage,and get some .03 and .06 shims and your good to go.
You wont need to measure the Manley setup.but it is crazy expensive.
Good luck with the build,it is Not a easy fix,for some extra HP up top.
2014-True Blue SLT,CC 6.4 BOX.
Air suspension,Rambox,Navigation.Backup camera.
3:92 gears.
Old 05-29-2013, 12:44 PM
Rep:36
I'm curren running this cam and the top in sucks. Can't say for hp yet but its not impressive
Performance mods
how to cam swap hemi moparmike07 Dodge Ram Knowledge Base 5 04-11-2013 10:17 PM
Arrington cam write up...4th Gen CHVYKLR Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 17 10-23-2011 12:21 PM
Front CAM Finally Installed. RansRAM Custom Dodge Ram Interior Modifications - Custom Audio / Video 38 09-27-2011 08:55 PM
new cam for mega cab? ohmega07 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 2 02-23-2011 11:30 AM
Custom Cam heavyfoot33 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 10 05-22-2010 03:01 PM
