Old 08-04-2011, 05:57 PM
sprintertech's Avatar
sprintertech sprintertech is offline
Vehicle: 2010 RAM
Trim Level: BIG HORN
Color: AUSTIN TAN
Rep:16
sprintertech is on a distinguished road
Originally Posted by 916timmy View Post
what is that cam part number so i can ask around?
05038419ab
Originally Posted by garner View Post
good to know if i mess up my r/t converter with towing since it's only rated at 5,000 pounds
you wont.....i think thats due to suspension more then anything
CMR TUNED(tweeked),K&N DROP IN, MODDED AIR BOX, NITROUS EXPRESS 150 SHOT, ARH 1 7/8 LONG TUBES NO CATS, BORLA XR-1, PRO TORQUE 2800 STALL, 4.56 GEARS, MOPAR LSD, ADJUSTABLE REAR LOWER CONTROL ARMS RELOCATED UNDER AXLE, GREDDY CATCH CAN, STICK PEOPLE IN REAR WINDOW......12.97@108...SOLD
Old 08-04-2011, 06:04 PM
garner's Avatar
garner garner is offline
Trim Level: Lonestar
Rep:46
I thought it was due to the torque converter or the 22" wheels since every other hemi ram can tow more than that with the tow package(which I have)
Gone but not forgotten:
First 2011 Ram R/T in Texas
Old 08-04-2011, 06:06 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
Good to know if I mess up my R/T converter with towing since it's only rated at 5,000 pounds
There was a bit a of a squabble going on at DT about the R/T verter being a POS with several plastic internals, that's why I asked.
If you ever have issue with your TC, replace it with a good "Custom Built" TC from Edge or Circle D for about the same price.
I ordered mine, custom built to my mods and specs from Andre at http://www.edgeracingconverters.com/
Old 08-10-2011, 05:01 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Any updates on the cam working or not???
Old 08-10-2011, 11:45 PM
Vehicle: 2010 RAM
Color: AUSTIN TAN
Rep:16
well honestly i was beginning to wus out.....i was speaking with eddie at southern hot rod today and ill probably be borrowing a corner in his shop within the next week or so and take a shot at it....at the same time i will be installing srt-8 jeep headers, custom y-pipe, muffler, next is a 125shot on a 3k window switch......and of course some tuning.....gonna do a nitrous tune too.....but i will def update the worth or damage caused by the 392vct cam!
Old 08-11-2011, 08:36 AM
916Timmy's Avatar
Rep:1443
Awesome! Can't wait to hear the results!!! Please lots of pictures and videos!
Old 08-12-2011, 10:33 AM
Blue Streak Blue Streak is offline
Vehicle: 2011 Ram 1500 Sport 4x4
Rep:63
Blue Streak will become famous soon enough
SRT8 jeep headers fit our trucks?
Old 08-12-2011, 10:49 AM
Rep:554
There's two guys on DT (adidas_kn and MGH) running stock SRT-8 exhaust manifolds, (look just like shorty headers)
but they had to customize them to get them to fit and clearance everything.
The steering linkage rubbing the heat shield on the drivers side, and had to be adjusted with a BFH,
MGH had to cut the top flange off of the cats and rotate them and weld them back on.
Relocation of the dipstick was required too, the passenger side one won't clear the frame rail without flattening out the collector area on the header.
thread: http://www.d o d g etalk.com/forums/showthread.php?t=313835
<cut&paste link remove spaces between dodge letters>
Old 08-12-2011, 12:25 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
blackramhemi: what do you have against regrinds?
I know little about vvt as I don't have it, but I understand it has to do with the lifters. Couldn't you swap out for regular hydraulic lifters and run whatever cam you want....? <<< may be stupid question...
Sean
Old 08-13-2011, 10:41 AM
Vehicle: 2010 RAM
Color: AUSTIN TAN
Rep:16
i ran a regrind cam in my brute force and had some issues....noticed metal during oil changes and further inspection revealed the cam was flaking apart....swapped to a billet cam and never had an issue....and the issue as i understand it is the same with automotive cams.....
as for the second question yes you can run a regular cam but its more then mds you also lose vct.....you would also be swapping out the cam gear.....but im not even sure if anythings available to do this type of swap......this is what i was initially going to do but i was going to have a billet cam cut to my specs....
how to cam swap hemi moparmike07 Dodge Ram Knowledge Base 5 04-11-2013 10:17 PM
Arrington cam write up...4th Gen CHVYKLR Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 17 10-23-2011 12:21 PM
Front CAM Finally Installed. RansRAM Custom Dodge Ram Interior Modifications - Custom Audio / Video 38 09-27-2011 08:55 PM
new cam for mega cab? ohmega07 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 2 02-23-2011 11:30 AM
Custom Cam heavyfoot33 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 10 05-22-2010 03:01 PM
