Old 09-08-2011, 08:53 PM
sprintertech's Avatar
sprintertech sprintertech is offline
Vehicle: 2010 RAM
Trim Level: BIG HORN
Color: AUSTIN TAN
Rep:16
sprintertech is on a distinguished road
Originally Posted by 916Timmy View Post
Steve White Motors, NC said the cam was a good part number and it was $64.26
springs were 172.96/16
pushrods were a couple bucks each
....SO 270-280 bucks ish for everything
and a stock Ram 5.7 cam was only 51.87, so 64.26 doesn't sound too far off!!
the pushrods are the same part for the 6.4 and the 5.7.....not needed!
CMR TUNED(tweeked),K&N DROP IN, MODDED AIR BOX, NITROUS EXPRESS 150 SHOT, ARH 1 7/8 LONG TUBES NO CATS, BORLA XR-1, PRO TORQUE 2800 STALL, 4.56 GEARS, MOPAR LSD, ADJUSTABLE REAR LOWER CONTROL ARMS RELOCATED UNDER AXLE, GREDDY CATCH CAN, STICK PEOPLE IN REAR WINDOW......12.97@108...SOLD
Old 09-08-2011, 09:39 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
So is the cam swap looking good?
Old 09-09-2011, 06:45 PM
mriboy mriboy is offline
Vehicle: 2012 Ram 2500 Outdoorsman
Trim Level: Outdoorsman
Rep:22
mriboy is on a distinguished road
Waiting to see results myself on the gains from this swap.
Airaid CAI , Fastman 85mm TB, Magnaflow 18", Magnaflow Y, JBA Shorties, Billet Tech catch can.
Old 09-09-2011, 09:56 PM
AirborneSilva AirborneSilva is offline
Vehicle: 2013 Ram Sport
Rep:74
AirborneSilva will become famous soon enough
I'm interested too, did you get your base dyno runs done? I'd like to see those as well. Thanks for testing this for us
2013 Ram Sport
1976 Corvette L82
Old 09-09-2011, 11:05 PM
916Timmy's Avatar
Rep:1443
Looking on some other forums, and found this....This is a post from Andy of Performance Werks Racing...or PWR, one of the best Hemi builders out there!!!
Yes it will fit, but the 6.4 has valve reliefs in the pistons. Without those, I imagine piston contact would occur in the 5.7 using that cam.
What do you think???? Is there any way to measure piston to valve clearance of the stock cam to see if the extra lift would be too much???
Old 09-09-2011, 11:33 PM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
I saw an article about a 5.7 build in Hot Rod. Try and find the article, it's a good read for what you are trying to do.
Old 09-10-2011, 12:29 PM
SS4Luck's Avatar
SS4Luck SS4Luck is offline
Vehicle: 2012 1500 Crew Cab
Trim Level: Big Horn 4x4
Color: Bright White Clearcoat
Rep:310
I dont know of any way to accurately check PTV clearance without taking the heads off and using the clay meathod
2011 Big Horn 4x4 -SnowWhite-
Old 09-12-2011, 02:07 AM
Vehicle: 2010 RAM
Color: AUSTIN TAN
Rep:16
this will stand as my base dyno run......you can check clearances with a dial indicator.....its not so much the difference in lift that will cause interference its the cam timing.....im aware that the 6.4 pistons have reliefs cut into them.....the 6.4 also has a higher compression ratio so the piston has more of a dome then the 5.7....i will admit that this is the concern that has me dragging my feet as its alot of work to have to back up......
as for the dyno numbers well..... i made less this time then last time but here it is.....
Old 09-12-2011, 02:12 AM
garner's Avatar
garner garner is offline
Trim Level: Lonestar
Rep:46
So only 9 rwhp over a stock 5.7? That seems like a really low gain. What are all your mods?
Gone but not forgotten:
First 2011 Ram R/T in Texas
Old 09-12-2011, 02:34 AM
Vehicle: 2010 RAM
Color: AUSTIN TAN
Rep:16
sorry...read the whole post...that is my base run.....bone stock truck with a predator.....no exhaust,headers,cai,nothin!
BTW most stock 09+hemi's ive seen roll on the heartbreaker (dyno dynamics) make less then 300whp.......
lol was a guy with a modded chevy truck after me only made 222whp and under 300whp on a 75shot.....
i will have everything (cam and springs) this week and will do my best to have it in next weekend....if it dont work out my truck will be apart till i get another cam.....no backing up!
how to cam swap hemi moparmike07 Dodge Ram Knowledge Base 5 04-11-2013 10:17 PM
Arrington cam write up...4th Gen CHVYKLR Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 17 10-23-2011 12:21 PM
Front CAM Finally Installed. RansRAM Custom Dodge Ram Interior Modifications - Custom Audio / Video 38 09-27-2011 08:55 PM
new cam for mega cab? ohmega07 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 2 02-23-2011 11:30 AM
Custom Cam heavyfoot33 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 10 05-22-2010 03:01 PM
