Warn wireless aux lights - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-03-2011, 12:53 PM
Turbovsix's Avatar
Turbovsix Turbovsix is offline
Vehicle: 2010 Dodge Ram Crew Cab
Trim Level: SLT Big Horn
Rep:85
Turbovsix will become famous soon enough
Default Warn wireless aux lights
All -
Anybody have experience with Warn's wireless aux lights? I'm looking to install these behind my grill and like the idea of not having to route wires into the cab.
Just looking for general feedback. They seem pretty cool, and the price isn't too bad either. I was looking at Lightforce units as well, but saw that Warn had these in wireless and kinda changed my mind....
http://www.warn.com/truck/lights/W65...g_Lights.shtml
Rich -
2010 Dodge Ram 1500 SLT Big Horn, Crew Cab HEMI
2017 Dodge Durango GT
2012 Jeep Grand Cherokee Limited (SOLD)
Old 08-03-2011, 01:04 PM
Upstater's Avatar
Upstater Upstater is offline
Vehicle: 2010 Dodge Ram Hemi SLT 4x4
Trim Level: Bighorn
Color: Stone White
Rep:132
Upstater will become famous soon enoughUpstater will become famous soon enough
Originally Posted by Turbovsix View Post
All -
They look pretty cool... I have the Lightforce 170's on my truck and there's no need to wire into the cab unless you want an auxiliary switch; mine are wired into the high beam circuit under the hood.
Old 08-03-2011, 01:07 PM
Turbovsix's Avatar
Rep:85
That's true -
You and I chatted about this on another post as well - I like how you tied those Lightforces in. They look really cool on your truck. I'm not a wiring expert, at least with my vehicles - when I'm looking at the wiring for the lights in my Ram, which wire do you tap into for the high beams (what color,in other words)...I just get nervous about hacking up the wiring...
I suppose you're right - if my existing high beams suck, which they do, why wouldn't I want them on with the high beams.
Rich -
Old 08-03-2011, 01:29 PM
Upstater's Avatar
Trim Level: Bighorn
Color: Stone White
Rep:132
That's true -
I don't remember the color of the wire, but on the high beams there's only 3; I suck at wiring so I bought an inexpensive circuit tester that lights up when pressed against the insulation of a live wire. I just turned on the high beams and checked the wires until I found the live one, tapped into that and I was good to go!
Old 08-03-2011, 01:42 PM
Turbovsix's Avatar
Rep:85
Oh cool - I've got one of those - that's what I'll do as well. Completely re-wired my house, but I feel like I don't know what I'm doing when it comes to this truck and the wiring. How did you tap into it - did you use one of those no-splice connectors (like scotch locks) or did you cut, splice, etc -
Think I've finally settled on the KC Slimlight driving lights - 100W each. I don't think I'm going to get the brightness I want with the Warn lights. Plus, the only Lightforce lights I can fit behind the grill are the 140 lance, and those may not quite give me the light I need either.
Thanks again for the help and input on this -
Rich -
Old 08-03-2011, 03:06 PM
highlandchef's Avatar
Rep:220
All -
I agree they look cool but I wouldn't want lights, that I might actually need, to be controlled wirelessly. I'd want them hard wired either to a switch or the high beams. If they are just for show then I guess that's ok. Personally I would only install lights because they are needed.
Old 08-03-2011, 06:45 PM
Upstater's Avatar
Trim Level: Bighorn
Color: Stone White
Rep:132
Sounds like a great choice. I'm old school when it comes to wiring on my vehicles, so everything gets soldered and finished off with heat-shrink tubing, then electrical tape.
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 20 12-13-2017 06:32 AM
Installed cab lights now no parking lights on right side MikeEB76 LD RAM - General Discussion 1 02-18-2011 11:26 PM
Third brake light causing the brake lights to stay on? Due Electrical 7 05-19-2010 02:33 PM
Part numbers for Lights? DarkRam01 Custom Dodge Ram Interior and Exterior Lighting 4 03-01-2010 11:50 PM
another trailer lights problem scbachman Newbie Checkin! 3 06-09-2009 07:55 PM
