Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 08-03-2011, 03:31 PM
MCTHOUSAND MCTHOUSAND is offline
Vehicle: 2004 Dodge Ram diesel
Trim Level: Texas tow package
Color: bronze
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
MCTHOUSAND is on a distinguished road
Default Rusted through oil pan
New member. I just discovered oil seeping through the side of the oil pan on my 2004 2500 Ram diesel four wheel drive. The Dodge place wants over 1200 dollars to replace the pan. Their price on the pan is 500 dollars and the rest is labor and gaskets and other shop materials.
Has anyone replaced the oil pan on this type of vehical and what is the proceedure. By the way, this pan is available at a discount online for just under 400 dollars.
The leaking pan has a plastic coating on it and looks like salty water got trapped behind it. Thanks in advance!
Old 08-04-2011, 09:25 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Welcome to the site; I don't have an answer so, it's time to .................... this back to the top! Drop by the Newbie Checkin and introduce yourself. Hope to see you around!
Old 08-04-2011, 12:50 PM
Color: bronze
I'm a retired metal fabricator/welder. My wife and I have been renovating a house in southwest Pennsylvania and enjoying gentile poverty. We do a lot of projects together, wood stuff, and ornamental iron. Also a little forging with a propane forge I built a while back. Life is good.
Old 08-04-2011, 03:28 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
no offense but if you're a retired welder shouldn't you be able to patch a metal oil pan...? I'd try to find a used oil pan on ebay or in a junk yard real cheap then pay someone to install it. Or figure out a way to patch yours.
Sean
Old 08-04-2011, 05:46 PM
Color: bronze
The pan is on the truck and has oil in it. The metal must be clean in order to repair it. To do a proper repair the pan must be removed. That is the problem. I had double knee replacement a while back and it is more difficult for me to crawl around under the truck. If all I had to do was take the pan bolts out to remove the pan, I would do the job myself. What I am afraid of is that the engine needs to be lifted up to wiggle the thing out. Thats why I asked about the proceedure for doing the job.
Old 08-04-2011, 05:49 PM
snrusnak's Avatar
Rep:1385
^ gotcha, I'm not sure on that truck, but usually the engine does need to be lifted to some extent to fit it over the crank and the frame crossmember. I'd probably find someone other than the dealer that'd do it cheaper.
Sean
1st Oil Change BLKSPORTHEMI Oil Change 41 10-12-2011 08:53 PM
Oil Entering the Radiator System SpecialEd 3.7L PowerTech V6 Specific Topics 6 07-15-2011 11:21 AM
Leaking oil filter? tcarlton0516 Dodge Ram General Discussion 12 05-19-2011 12:50 PM
My first post... About my Ram and Work Done ramvan2500 Newbie Checkin! 14 04-24-2011 08:23 PM
