Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > LD RAM > 2010 Dodge Ram Forum
Old 08-04-2011, 03:26 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Default Weatherstripping between bed and cab?
Anybody know what the purpose of the weatherstripping between the bed and the cab on each side of the trucks on 4th gen rams is? I assume it's to keep rain and debri blowing in there since the cabs/beds are contoured naturally in that direction...
Sean
Old 08-04-2011, 04:43 PM
rsg1963's Avatar
rsg1963 rsg1963 is offline
Vehicle: 2016 RAM 3500; 2010 RAM 1500
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
Rep:48
rsg1963 is on a distinguished road
My understanding is that this is a trim piece to eliminate the "gap" that would otherwise be there. Meaning it would lend to a very cheap look and seem to be 'mis-installed' without it. Too much light shining through and seem like the bed was too far back without it.
Wind, rain and debris can get all in there anyway (and does). The beds move quite a bit on Pickups (Fords are the worst for this) so the gap is needed.
2010 1500 Laramie Hemi: Magtec Rear Diff cover, 24" Magnaflow, Resonator delete, Line-X; Bilstein 2.75" kit;295/60-20 Wrangler Silent Armor Pro Grade; Lift Air Bag
2016 3500 Laramie MC: Bilstein 5100's up front, 20" Fuel rims with 275/65-20 Micheline LTX MS/2 tires, Weathertec Floor mats, 45 gal RDS tank, Hensley TS3 hitch, Billet DEF and Diesel caps, DeeZee tailgate assist, Bull Ring retractable stake pockets, Amp Research steps, hybrid window tint.
Old 08-04-2011, 04:59 PM
LBZ HEMI LBZ HEMI is offline
Vehicle: 2010 Ram
Trim Level: SLT Bighorn
LBZ HEMI is on a distinguished road
i was told by the dealer it was for aerodynamics keeps the air flow smoother thus less drag so i was told
Old 08-06-2011, 08:44 AM
BlackBullet's Avatar
BlackBullet BlackBullet is offline
Vehicle: 2010 Ram Hemi TRX4
Trim Level: TRX4
Color: Brilliant Black Met
Rep:45
BlackBullet is on a distinguished road
heard this as well. dealer was really pushing aerodynamics on me too. i like it. looks good and sort of a debri shield. doors have it too.
Leveling kit, DSP tuner, 14" MAGNAFLOW with side exit, heavy duty DODGE slush mats, DODGE bed mat,BILLET TECH catch can, STAINLESS steel door sills, K@N drop in filter, level ride airbag suspension....
Old 08-06-2011, 09:24 AM
highlandchef's Avatar
Trim Level: SLT Big Horn
Rep:220
It might be but the increased aerodynamic efficiency is probably very slight. I think looks has as much to do with it as aerodynamics but it doesn't hurt either.
Old 02-02-2014, 05:44 PM
joedw00 joedw00 is offline
Vehicle: 2010 Dodge Ram 1500 long bed
Color: True Blue
joedw00 is on a distinguished road
Default Low air blowing from Heater blower
I just bought a 2010 Ram SLT. I only has 10,000 miles on it. I have noticed that there is not very much air coming out of vents with it on high and recirculation on, I have search the forum and found nothing on it. Has anyone had this trouble?
Old 02-05-2014, 08:17 AM
ric221's Avatar
ric221 ric221 is offline
Vehicle: 2016 Ram Sport
Trim Level: SPORT
Rep:21
ric221 is on a distinguished road
I have not seen or heard of this issue. I have a 2010 ST, my heat runs like this Hot or Cold no in between. Have not tried the recirculation mode. Will try it out to see if I have the same issue.
Hope This Helps You In Your Quest
Old 02-05-2014, 10:18 AM
bartlett bartlett is offline
Vehicle: 2013 Ram quad
Color: gray
Rep:323
bartlett is a jewel in the roughbartlett is a jewel in the roughbartlett is a jewel in the roughbartlett is a jewel in the rough
In my area we get alot of leaves ect in the fall. I looked in that area one time and it was full of leaves. My worry is the leaves/water rusting that area. I think I might remove the strip just so its not a catch all.
Old 02-05-2014, 06:36 PM
thebluegoat thebluegoat is offline
Vehicle: 2011 Ram 1500
Color: Deep Water Blue Pearlcoat
Rep:49
thebluegoat is on a distinguished road
The strip is there for aerodynamics. Something about keeping turbulent air moving or something like that. If you're ever under your truck, or look between the bed and cab, you'll see another rubber strip horizontally at the bottom of the bed which is another aerodynamic piece.
Old 02-06-2014, 10:12 AM
Gottarpon Gottarpon is offline
Vehicle: 2010 Ram 1500 Big Horn 4X4
Color: Vanilla
Gottarpon is on a distinguished road
One of mine fell off
