Old 08-04-2011, 06:20 PM
Clifton's Avatar
Clifton Clifton is offline
Vehicle: 2011 Dodge Ram 1500 Crew 4x2
Trim Level: Lone Star
Clifton is on a distinguished road
Default Dual In / Dual Out Muffler - Anyone Running One?
Ive been thinking about going with the Dual In / Dual Out Muffler - cutting the system after the cats, then running dual pipes into a single muffler then out the back through the stock pipes and tips. Im only thinking about a 22"-24" Muffler in either Magnaflow or Pro-Flo.
Is anyone here running this set up? Ive seen lots of threads about replacing the Y-Pipe then going single in dual out, but none on dual/dual mufflers.
Is there a reason why people are not going this route? Is it a back-pressure issue? Will it bother the O2 sensor and throw codes?
Any help would be much appreciated. Thanks!
2011 Ram Hemi Crew White - DynoMax VT Muffler - Drop in K&N - De-Badged - Spray in Bed Liner
Old 08-04-2011, 06:49 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
I think it is a pretty tight fit for duals with the gas tank and everything. I think it could be done. I have seen duals back to a muffler then a single out dumped under the bed, so if that works, i bet yours would too
Old 08-04-2011, 07:06 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Originally Posted by Clifton View Post
Ive been thinking about going with the Dual In / Dual Out Muffler - cutting the system after the cats, then running dual pipes into a single muffler then out the back through the stock pipes and tips. Im only thinking about a 22"-24" Muffler in either Magnaflow...
I was discussing the same installation with my muffler shop and his only recommendation was to have a cross-over between the muffler and the down pipe to equalize pressure. When I can afford it that's the way I think I'll go.
Old 08-04-2011, 07:25 PM
916Timmy's Avatar
Rep:1443
It's easy to add a small H in the front!!!!! Check out Chefred112's setup, it might help you with ideas!
Old 08-04-2011, 08:06 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
magnaflow's dual in dual out also has an xpipe inside of it...
Sean
Old 08-04-2011, 11:27 PM
Clifton's Avatar
If the Muffler has an X inside of it, wont that create enough pressure in the system to keep it from having problems with throwing codes?
Old 08-04-2011, 11:43 PM
snrusnak's Avatar
Rep:1385
You won't get any codes from losing pressure. There's a huge myth out there that removing exhaust pressure makes you lose low end, that's not at all true. In some cases, having a smaller exhaust pipe diameter can help increase the gas velocity, helping to scavenge, but really doesn't have to do with pressure. You could cut your entire exhaust off from about 3 feet behind the cats and not get a code. I should also add that the x pipe in magnaflows muffler is not extremely good flowing, but is good.
Sean
Old 08-04-2011, 11:50 PM
Clifton's Avatar
I went to one muffler shop today and they said they wouldn't recommend getting away from the single in dual out muffler because it would cause codes. Then another muffler shop recommended the exact opposite with cutting after the cats, and running duals into and out of a muffler with an X inside like Flo-Pro.
I hate getting conflicting stories! Then I called the local dealership and talked to the service mgr and he said that anything cats back wont void the warranty, but he couldn't guarantee that it wouldn't effect the O2 Sensor and throw codes...
I dont know who to listen to at this point...
Old 08-04-2011, 11:56 PM
snrusnak's Avatar
Rep:1385
Really, anything behind the cats will have absolutely no effect on codes or warranty....
The first shop just didn't want hard work that's why they told you that (*ssholes). They can very easily swap in a muffler that's nearly a direct fit and still charge you decent money and make a larger profit vs doing all that work for duals. You really won't gain much power or sound with a dual setup or x pipe, maybe AT MOST a couple peak hp, I've seen dynos with y pipe, vs same setup with x pipe, and they are around like 2 peak hp gain, and that could even be in the dyno's error margin or due to temperature (probably really is slightly better though). If you do a y pipe they can reuse your 3" stock pipe and save you money. I'd recommend going with an aftermarket y pipe (magnaflow) and then reusing the stock 3" pipe after that, then doing a single 3" in/dual 2.25" out to connect to the existing stock tailpipes. magnaflow has nice mufflers too, will last forever and perform well, sound good too.
Sean
Old 08-11-2011, 11:07 AM
Clifton's Avatar
Has anyone used Flo-Pro or DynoMax mufflers? I really like the sound of the Magnaflow, but I havent heard much about theses two. I know I dont like the sound of the flowmaster.
I really think I am going to go the route of duals from cats back into a DI/DO muffler and utilize the factory rear pipes and tips. The shop that I want to do the job seems pretty pricy though. They want $410+Tax ($444). That includes all parts and labor. Does this seem excessive? I know this shop does great custom work, and is one of the best in the DFW metroplex. I dont want to skimp and get shotty work on my expensive new truck, but is it really worth the extra cash?
True Dual dumps or stock exhaust with 1 in 2 out muffler? j2010ray 4.7L PowerTech V8 Specific Topics 4 01-23-2011 12:38 PM
WTS - 09+ RAM Dual Exhaust Muffler jmr Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 6 10-04-2010 12:41 PM
WTB - Stock 09+ Sport or R/T dual exhaust muffler jmr Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 3 09-30-2010 11:26 AM
Running Muffler less! Gron86 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 11 06-29-2010 02:29 AM
which muffler will fit the stock dual set up? Quiet Lunatic Exhaust 7 05-05-2010 12:44 PM
