Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 3.9 Liter V6
Custom Dodge Ram Performance Mods - Engine - 3.9 Liter V6 Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 08-04-2011, 11:34 PM
cjmiller89 cjmiller89 is offline
Vehicle: 1993 Dodge D150 Ram
Trim Level: base
Engine: 1992-1991 239ci (3.9L) Magnum V6 180hp
cjmiller89 is on a distinguished road
Default Transmission talk
Hey hows everybody doing? Im building a 360 magnum and I wanna know what the best transmission to use to hold a good amount of power?
Old 08-06-2011, 01:01 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
Well I do know that the 46 series has been on the 318 and 360 only however you could just bump up and find a 47 or 48 which the 48 was used on the diesel just be sure the mounting is the same, I would probably just get a 47 series.
Old 08-06-2011, 09:08 PM
HemiLonestar's Avatar
Rep:280
If it is going into a '93 D150, then find an early 90's A518. It's a 727 with an overdrive section. Comes with a small block bolt pattern and all you have to do is rig a simple switch to engage the overdrive (no computer). If you do a 'mopar action 518', Ehrenberg has a pretty good write up about.
"Big Red"
2006 Charger R/T
Old 08-06-2011, 09:44 PM
ramvan2500's Avatar
Rep:128
Like said a 46 47 or 48. I prefer you get the 46RH because it doesn't require a PCM and the OD is turned off by a switch which you can actually get from autozone but of course you can wire a little old toggler. Anyways the A518 is a 46RH actually, I really love the 46RH I believe it is a very ruggid and powerful transmission if you up the planets on it to distribute the load and change out the acumulator piston and the servos for some billet multi seal ones and do a few here there things you can really turn that into a performance transmission. Now you can just upgrade the frictions get more holding power use a 4.2 ratio kick lever with 2 3/16" bands I would use carbon but they're over 100 bucks however it's not bad they are really good. When I do my rebuild I am going for performance/heavy duty parts. Anyways yes just shoot for a 46
Just ordered Arrington Big Valve Heads RamTex Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 19 07-08-2011 03:38 PM
2001 Ram1500 5.2 L Transmission shifting problems Mic Shaw 5.2L V8 Specific Topics 12 06-13-2011 09:29 AM
Transmission won't shift Hlmeans 5.7L V8 Specific Topics 1 03-27-2011 11:48 AM
45/545 RFE Transmission Overview RamTech Dodge Ram Knowledge Base 13 02-04-2011 04:13 PM
Transmission has slight shift delay??? Quiet Lunatic V6 Specific Topics 5 02-05-2009 06:09 PM
