Supercharger or Turbocharger - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8
Old 08-12-2011, 12:08 PM
bigredtruck's Avatar
bigredtruck bigredtruck is offline
Vehicle: 2008 Dodge Ram
Trim Level: SLT BigHorn
Color: Husker Red
bigredtruck is on a distinguished road
What always stopped me from doing forced induction was tuning.....but it seems tuning has become more available and easier...
True, any performance shop will tune your vehicle for a reasonable price. Tuning is EVERYTHING so even a couple hundred bucks is well worth it!
Old 09-08-2011, 10:21 AM
BMD0947's Avatar
BMD0947 BMD0947 is offline
Vehicle: 09 Ram Quad 4x4 4.7L
BMD0947 is on a distinguished road
I went to AirRams site but didn't see anything about turbos for our engines. Does anyone know what size turbo is recommended for our motor? I have a brand new complete setup that was for a tacoma 4cyl engine. The kit has the Garrett T3/T4 turbo. It would be cool to pick up a second one if it will work on this engine and start building a twin turbo 4.7L!!
Old 09-08-2011, 10:30 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
Airram only has the supercharger kit they are working on as far as I know, nothing turbo...
I know a little about forced induction, but not enough to say I'm an expert, and I don't know how to size them to an engine, it has to do with trim, etc..., etc.... but if it was designed for a 4 cylinder I'd guess it'd be too small. You could also do a single turbo, doesn't necessarily have to be twin turbo to perform well. Human beings have this weird need to be symmetrical.....it's not necessarily needed though.....I saw a small block chevy v8 that had a single turbo off of one manifold, the other manifold did not connect to the turbo in any way, and the car ran like a bat out of hell.
Sean
Old 09-08-2011, 11:39 AM
BMD0947's Avatar
That's a good piece of info, I like the idea of twin turbo but I guess it's not needed. Does anyone know what the benefit of twins would be versus single?
Based on some research, the T3 T4's are a good setup for most V8 applications
I am not a Ford fan but I found this:
"When it comes to street turbos for 5.0L or modular Fords, there are basically two common sizes: the T3 and the T4. Sure, there are a few crazy individuals out there who opt for the large frame monsters, but the T3 and T4 families can serve the needs of just about any V-8 from mild to wild."
Read more: http://www.musclemustangfastfords.co...#ixzz1XNMxvhvx
Old 09-08-2011, 12:05 PM
snrusnak's Avatar
Rep:1388
I know going too big causes spooling lag...I'd think with twins you would have less lag because you could run two smaller turbos instead of one larger...again this isn't something I have alot of experience with though. I've dealt mostly with NA applications...Also forced induction likes cams with little to no overlap.
Sean
Old 09-08-2011, 01:35 PM
bombadillo's Avatar
bombadillo bombadillo is offline
Vehicle: 2011 Dodge Ram 1500 4x4
Rep:25
bombadillo is on a distinguished road
I would love to see a T3/T4 Twin turbo'd 4.7L. I just wonder if the bottom half of the motor could hold up to the horsepower. You'd need a lot of work done too on the fuel system to keep up with all that air. That combined with the 2011's (which I have) and they haven't cracked the codes for things yet so its a bit frustrating. I won't do anything wild till my warranty runs out then its MOD TIME!!!
2011 4.7L with AVS ventshades, Vision 375 Warrior wheels, Daystar 2.5" leveling kit, GTS Blackout taillights. Magnaflow exhaust done custom, (sounds AWESOME) and I'm sure more to come.
Old 09-08-2011, 01:39 PM
snrusnak's Avatar
Rep:1388
The bottom end of the engine is pretty strong; The new 4.7L (don't know about the first gen) does not use individual main bearing caps, it uses something similar to a cradle, I bet it would be damn near bulletproof. I don't know about the crank, rods, and pistons/rings, but I'd guess the weakest link would be the rings. I'd think you could run mild boost and not have any issues, it seems to be a very strong bottom end from what I've read, at least stronger than most other engines.
Sean
Old 09-08-2011, 06:41 PM
BMD0947's Avatar
Well I need all the info I can get about this. If your gonna do it, do it right!
Old 09-08-2011, 06:44 PM
Drake371's Avatar
Drake371 Drake371 is offline
Vehicle: 2008 Dodge Ram 1500
Rep:83
Drake371 will become famous soon enough
I might not be able to afford it, but I really want to see it done.
Superchips Cortex, K&N CAI 63-1529, Sprayed in Bedliner, ARE cover, Flowmaster exhaust kit ... more to come
Old 09-10-2011, 11:11 PM
taylal's Avatar
taylal taylal is offline
Vehicle: 2011 2500 crew cab 4wd
Trim Level: st
Color: dark gray
taylal is on a distinguished road
Default turbo's or superchargers
i would love it to turbo or supecharge my 4.7 i tow 30' trailer any help would be great, is thier someone out thier with a bolt for a 4.7,n
ext step air ride
1500, 4.7l, ram, super, turbo
SuperCharged Hemi RAM thanks to Magna Charger azzo540 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 240 11-30-2015 01:19 PM
Saleen Supercharger for the 5.7L Hemi gregster Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 12 10-16-2010 03:30 PM
Turbocharger vs. Supercharger randy Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 34 10-12-2010 06:40 PM
turbocharger versus supercharger randy South West 1 03-27-2010 10:00 PM
