Old 08-05-2011, 10:45 AM
X3RX3SRagDoll X3RX3SRagDoll is offline
Vehicle: 1997 Dodge Ram
Engine: 1995-1997 318ci (5.2L) Natural Gas V8 200hp 430lb/ft
X3RX3SRagDoll is on a distinguished road
Unhappy Front passenger wheel.
Recently my front passenger tire has been sitting out quite a good bit. Alignment and rotations on fix it temporarly. So I replaced the U-Joint and it fixed it for about 2 months. Then the other night I was driving to work and noticed my steering was real bad off and it was shaking more than normal (it shakes till I get up to about 55mph havent figured that one out either). Well when I parked I check both front tires. My steering wheel was sitting almost sideways but my driver side tire was pointing straight and my left tire is now turned a slight bit out. All the ball bearings were replaced about 5 months ago. But also come to think of it nothing was really wrong with that tire until I had to have the passenger leaf spring replaced. Help?
Old 08-08-2011, 11:43 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I'm not sure I have an answer - so how about a Have you had the tie-rod ends checked and had a full alignment done?
Brittany, How about using the link in my SIG to jump over to the Newbie Checkin to say Hi and post a few photos of your truck?
Old 08-10-2011, 12:21 PM
Tie-rods and full alignment has been done. i even replaced the shocks and it didnt solve the problem either
Old 08-10-2011, 12:28 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
If one tire is pointing straight and the other is not (if the tires don't point pretty much exactly the same direction), it has something to do with the steering links/tie rods/tie rod ends. I'd recheck them, look over them again to be sure, that's the only reason the wheels would point in different directions....
Sean
Old 08-10-2011, 03:46 PM
I agree with ^^^^ that. Those are the parts that keep the wheels pointing in the right direction!
Old 08-11-2011, 12:41 AM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
I 'd be looking at the wheel bearings, they wouldn't show up to an inexperienced aligner, they'd be correcting everything except the problem. jack up both front wheels, one at a time, and roll em around by hand, bent wheel? do they have slop, side to side, or wiggle if you pull on the top in and out??? when you're driving, and apply the brakes, does it pull in either direction, or does the brake pedal jump up and down a little??? Has your track rod been looked at on the drivers side end, when someone is gently turning the steering wheel back and forth, if the ballsocket is moving up and down, theres a permanent fix for it known as "Lukes Link" a really good product sold by a guy out of Colorado, it's also a great permanent fix for the long tierod ballsocket, wish I had invented it, priced very reasonably, only basic tools are required to install it. I don't know of anything else that hasn't yet been mentioned. Remember, the best guarantee of a job being done right, is to do it yourself, or at least properly troubleshoot so you can tell a maintainer exactly what the problem is , and what you have found in looking into it yourself!!! Good luck!!!
Old 08-11-2011, 12:45 AM
Color: 1 Blk,1 Red
Rep:36
OK, now I feel stupid, I had assumed that you had a 4x4, now I see that it is not? AND powered by natural gas??? Hmm, I don't see any vehicles like that up here in snow country, sorry...
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 160 05-19-2015 09:42 PM
Sound from front right wheel area sullivan Suspension 2 04-09-2011 04:34 PM
02 4x4 front wheel bearing replacement edgeracing Suspension 6 02-23-2011 10:00 PM
Something dripped on the front passenger side floor mat.... LonghornLaramie 2010 Dodge Ram Forum 13 02-15-2011 04:38 PM
'96 1500 ram 4x4 front drivetrain binding chewey 5.2L V8 Specific Topics 0 10-20-2009 09:57 AM
