Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 08-05-2011, 11:25 AM
X3RX3SRagDoll X3RX3SRagDoll is offline
Vehicle: 1997 Dodge Ram
Engine: 1995-1997 318ci (5.2L) Natural Gas V8 200hp 430lb/ft
X3RX3SRagDoll is on a distinguished road
Angry Overheating
Ok so ive replaced all the gaskets, all the hoses, the clutch fan, the water pump, the radiator, and the thermostat and it is STILL overheating, but only when im sitting still like at a red light or when im stop go stop go in traffic. Also I dont know if this has anything to do with it but when I turn my A/C on it does nothing but blow hot air.
Old 08-05-2011, 01:11 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Sure sounds like a fan issue....AC not blowing cold makes sense if it had a fan not working properly as the condenser is not pulling air through to cool it. Are you sure you put the thermostat in the correct way, with the correct orientation? This does matter. Also could be air purged in the coolant. To make sure all the air is out of the system do this: Lift front of vehicle slightly so that radiator cap is elevated. With engine cold, unscrew radiator cap, start engine, turn the temperature knob as hot as it goes, and switch the vent selector to the floor. let the engine get to operating temperature, as the thermostat opens and closes, the coolant will flow through the engine and throught the heater core and should purge all air to the highest point (radiator cap opening). Let it run at operating temp for 5 min then you should have all air out. It's gotta be either the fan, the thermostat, water pump, or air in the system...
Sean
Old 08-05-2011, 05:01 PM
I burped the hose the other day because I have a gurgling noise through the dash when I start the truck but it stops shortly after I drive it for a few mins. When I get the first chance I'll do as you suggested because everything has been replaced and is new trying to solve this problem.
Old 12-31-2011, 06:41 PM
pkmachinegun's Avatar
pkmachinegun pkmachinegun is offline
Vehicle: 2001 Dodge Ram 1500
pkmachinegun is on a distinguished road
funny story, i have all the same symptoms in my truck but i dont get gurgling in the dash...ive only replaced the water pump because thats what ive had time for. i do beleive that there is a leak somewhere in my cooling system (ive seen heavy moisture coming from the hose coming out of the top of my water pump) because i carry distilled water in my truck so when it does decide to get above 210 i can just top it off....unfortunately im deploying here in a few days so i dont have time to fix it before i go.... =/
Old 12-31-2011, 08:04 PM
Ram10tuff Ram10tuff is offline
Vehicle: 2010 Ram CC
Ram10tuff is on a distinguished road
Just a shot in the dark... Try flushing the heater core. Does the truck have good heat?? Did ac work before this problem started? You spens some bucks changing all of that for nothing to work there has to be something your missing
Old 12-31-2011, 08:51 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Take it to a car wash and blow out radiator, we have to do that with our co. trucks once a y ear. Also I agree on core clean out.
Old 01-06-2012, 12:27 AM
panhead's Avatar
panhead panhead is offline
Vehicle: 1996 Dodge Ram 2500
Trim Level: WS
Rep:103
Have you tried replacing the temperature sensor? They do go bad and I would try a new sensor since you had revamped the cooling system. With the items you replaced, it should run at normal temps.
Old 01-06-2012, 12:46 AM
Rep:2657
having a 1997 Ram, i would suggest going to a good radiator shop, have them run the tests, usually it is FREE, they want your business
a 10 year old radiator has to be partially blocked
If it is, you can pull it yourself & save money, or have them pull it
they will tell you when they do the tests, whether it needs RODDING OUT, or replacing
A new radiator costs about $170 just to give you an idea, it may be less through the radiator shop
Rodding Out should be less
Labor cost is the killer, so if you do it yourself, you would save a bit
have the shop tell you if you need new hoses
also have them flush the heater core
overheating when pulling serj5150 4.7L PowerTech V8 Specific Topics 3 05-02-2011 04:54 PM
Heating Problem, and Truck Overheating. Related? hockeyplaya13 Heating & Cooling 2 03-14-2011 03:26 PM
Overheating Prevention braggable Heating & Cooling 4 08-20-2010 09:19 PM
overheating 4.7 Mark 4.7L PowerTech V8 Specific Topics 2 07-19-2010 01:10 AM
Overheating, no heat in cab, 03 Ram 1500 jvigier Heating & Cooling 3 02-08-2010 07:29 PM
