Old 08-05-2011, 12:58 PM
crissk13 crissk13 is offline
Vehicle: 2003 Dodge Ram 1500
Color: Blue
crissk13 is on a distinguished road
Default Coil Spacers on a 3 inch Rough Country Lift
I have a 2003 Dodge Ram 1500 2WD Single Cab. It has a 3 inch rough country suspension lift. the front is 1.5 inches lower than the back and i want to level it. daystar makes a 1.5 coil spacer kit, but the local shops dont know for sure if the truck will realign all the way. I need someone to advise me, or i need someone that has already done it, to tell me if it will work or not. PLEASE HELP!
Old 08-05-2011, 02:50 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Its not really recomended to put spacers on top of a lift spring. With that much you might need a longer pitman arm, adjustable track and a sway bar relocator bracket, but I'm not completly sure
Rough Country 4 Inch Lift (PN352) Ramathorne Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 03-18-2012 11:53 AM
anybody using the rough country 3 inch suspension lift kit? firerescuedodge23 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 07-13-2011 09:24 AM
Need help with 3" Rough Country Suspension lift steelman512 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 02-20-2011 03:15 PM
rough country 3" lift??? countryboy85 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 19 08-15-2010 01:13 PM
6 inch fabtech vs 6 inch rough country srtsir Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 5 08-08-2010 10:11 PM
