Old 08-04-2011, 07:30 PM
06 BigHorn's Avatar
06 BigHorn 06 BigHorn is offline
Vehicle: 2012 Dodge Ram
Trim Level: Express Quad Cab
Color: Deep Cherry Red
Rep:153
06 BigHorn has a spectacular aura about06 BigHorn has a spectacular aura about
Default HELP ! Lower strut bolt problems
I'm trying to replace my stock front struts & springs with some Monroe quick struts but the lower strut bolt is seized in the bushing. I tried pounding it out to the point the bolt is starting to mushroom. Tried using a puller & that didn't move the bolt either. The bolt does NOT turn.
If the bolt is seized this bad is the bushing destroyed? If I heat it, will that destroy the bushing? I can't find a replacement bushing online & other similar topics talked about having to replace the whole lower control arm.
It's a truck, not a cream puff
Old 08-08-2011, 11:36 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I'm not sure I have an answer - so how about a
problems removing the lower strut bolt on 2006 1500 breck83 Suspension 9 04-18-2014 05:19 PM
interior lights in 98 ram 1500 lacamu Custom Dodge Ram Interior and Exterior Lighting 6 08-12-2011 02:43 PM
Can a broken exhaust bolt cause real problems? bigred0603 4.7L PowerTech V8 Specific Topics 1 06-05-2011 12:39 AM
cant get bolt of strut rod sullivan Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 7 03-17-2011 04:19 PM
lower control arms cam bolt tuckertrucker Suspension 2 02-25-2011 12:25 AM
