Old 08-05-2011, 04:37 PM
herc herc is offline
Vehicle: 2011 Ram 1500 Quad Cab 4x4
herc is on a distinguished road
Default Does Everyone have a Noisy Torque Converter?
Ok, so here's the deal. A number of other threads on this and other forums were about a "growling" noise sometimes heard, and the common finding was that it was coming from the torque converter. I described the noise as sounding like "a frisbee sliding accross smooth pavement". Dragging an upside-down plastic garbage can cover might be another close one.
So, even though others seem to have had some satisfaction when their dealers replaced the torque converter, mine's claiming that it's a totally normal noise that "all of the new Rams make". They claim that they actually took two other brand new trucks off their lot and they both exhibited the same noise.
I hear this noise all the time, but here's a sure-fire way to get it to happen. Take the transmission out of full auto mode, and set the display to max at 4. Then get yourself going so that you're IN 4th with engine about 1500-1600 RPM. It works best if you can hold it there with a little pedal pressure, so a slight incline helps a lot. Some days it's louder than others, but when it's loud, you can hear it over the radio.
I believe what's happening is that the TC clutch is "kind-of" closing, but not really locking, and the noise is coming from the clutch dragging along a little slower than the flywheel. I don't have any scientific data to prove any of that, but that's my guess.
Anyway, I'm REALLY curious if every truck really does this. If you KNOW yours does or doesn't, I'd appreciate knowing that. If you don't know, and are willing to try my test above, I'd be curious what your results are.
WARNING: Don't do the test unless you're actually willing to find a new noise that you didn't know yours had. I'd hate to spoil anyone's day.
Thanks!
Old 08-05-2011, 08:14 PM
Wayne084 Wayne084 is offline
Rep:53
Wayne084 will become famous soon enough
I have the exact same symptoms at the exact same rpm's. I think the tc's are all the same, but for some reason my boss' 09 ram hemi doesn't do it nearly as predominantly. But my 11 is RAUNCHY! Don't get me wrong, I don't think it's right, however I think that a very large percentage of them do it, and they probably won't fix unless a recall is eventually issued due to the fact that they would be setting a huge precedent since so many of them do it (just my assumption)
Old 08-09-2011, 07:38 AM
estoltz estoltz is offline
Vehicle: 2011 Dodge Ram 1500 5.7 4x4
estoltz is on a distinguished road
Mine does it at those exact ranges. It is also louder when towing 8,000 lbs. At this point it is enough that I need to turn up the radio. I just need to find time to put it in the shop.
Old 08-09-2011, 01:34 PM
stangallmotor stangallmotor is offline
Vehicle: 2011 RAM R/T
Trim Level: R/T
Rep:60
stangallmotor will become famous soon enough
My doesnt make any sounds, I think you guys need something repaired ASAP!
Old 08-09-2011, 04:05 PM
BassRam BassRam is offline
Vehicle: 2011 Dodge Ram Sport
Color: Deep Cherry Red Pearl
BassRam is on a distinguished road
Try this thread
http://www.ramforumz.com/showthread.php?t=84348
Old 08-09-2011, 11:11 PM
cudase's Avatar
cudase cudase is offline
Trim Level: Sport Crew Cab
Color: Mineral Gray Metallic
Rep:53
cudase will become famous soon enough
Quiet now that I have a new torque converter.
Old 08-10-2011, 07:47 AM
Skidoo Dad's Avatar
Skidoo Dad Skidoo Dad is offline
Vehicle: 2011 Ram Crew 4x4
Trim Level: Outdoorsman
Skidoo Dad is on a distinguished road
My 2011 Outdoorsman did the same thing last week coming back from camping towing 4000 lbs. It would only happen when going steep grades and with the rpm at 4000. Sounded/felt like when you drive on soft shoulder, just a bit quieter. It never happened again without trailer in the back after. Will communicate the info of the other thread (TSB) to my dealer today and see with what they come up....thanks !
Old 08-10-2011, 07:55 PM
Second Life's Avatar
Second Life Second Life is offline
Vehicle: 2011 Ram 1500 Crewcab
Trim Level: Outdoorsman 4x4
Color: Deep cherry red
Second Life is on a distinguished road
No noise with my 2011, but then again i'm deaf and hard of hearing.
Truxedo LoPro - Westin Premier 6'' Oval tubes - Sonnax line pressure booster - Dee Zee rubber bed mat - Magnaflow 12259 - K&N Aircharger - Bilstein 5100 set at 2.8'' - BullyDog GT for Hemi Plus
Old 08-11-2011, 05:46 PM
geener geener is offline
Vehicle: 2010 quad cab ram1500 4x4 hemi
Trim Level: sxt apperance group
Color: inferno red
geener is on a distinguished road
My 2010 had the exact same noise at the same rpm range 4 visits later the torque converter was changed. There is a STAR service bulletin for this problem. Good luck !
Old 08-11-2011, 08:41 PM
united316 united316 is offline
Vehicle: 2011 Dodge Ram Crew Cab SLT
Rep:87
united316 will become famous soon enough
I have never heard any noise coming from mine. I will keep an ear out though.
2011 SLT Crew Cab 4x2, 4.7, 3.55 gears, TruXedo TruXport Soft Roll-Up Dual Latch Tonneau, Westin Black Platinum series oval step bars, Aeroskin Hood Protector, Ventvisors In-channel smoke , Husky Liners Front ard Rear Mud Guards, K&N drop in air filter.
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 04:16 PM
Torque converter..which one and where? Travis Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 4 02-28-2010 06:13 PM
Blue torque converter DODGE4x4 Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 2 02-09-2010 10:09 PM
Torque converter questions... blazn189 Off Topic Discussion 2 12-14-2009 10:02 PM
Torque converter seems to be locked iceracer 5.9L V8 Specific Topics 6 09-25-2009 12:04 PM
