Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 08-06-2011, 12:32 AM
Joseph W. Joseph W. is offline
Vehicle: 2001 Dodge Ram 1500 4X4
Joseph W. is on a distinguished road
Default a/c at idle?
my 01 1500's a/c blows fine as long as your moving, but at a red light or drivethru, the ac stops blowing cool and turns to warm-cool... also, the fan isnt blowing quite as fast as it used to be, when i bought it the blower was blowing so hard you had to raise your voice to talk to your passengers, not you barely hear it and it's hardly blowing out of the vents. one other problem is that this truck recently developed a problem with getting too warm at idle... if i have to set in line too long at idle the temp creeps up to around 210deg. once i start moving it cools back down quickly. when i bought the truck the vacuum lines by the condenser that controls the vacuum into the cab were broke... once i reconnected them the selector knob on the dash is backwards... defrost is actually max a/c, max a/c is defrost, and any other setting just closes all the doors so that very little air comes out of the vents. what is going on here? are there common issues?
Duct tape is like the force, light on one side, dark on the other, and holds the universe together.
Old 08-06-2011, 03:55 AM
strang3majik's Avatar
strang3majik strang3majik is offline
Vehicle: 1996 Dodge Ram Indy Pace Truck
Trim Level: Indy Pace Truck
Color: Blue w/ white stripes
strang3majik has a spectacular aura aboutstrang3majik has a spectacular aura aboutstrang3majik has a spectacular aura about
Check your fan clutch. Engine off (posted for liability sake ) grab the fan and see if it wobbles any, if it does...your fan clutch is bad.
If it is, its not cooling it sufficiently at idle and not pulling enough air across the a/c condenser to make it operate correctly.
If that is indeed the problem, make sure you get a fan clutch from Dodge. If you get a parts store clutch, it'll spin all the time and kill your power/mileage and make your truck sound like a prop plane.
As far as the blower motor/ could either be the relay for the switch or the blower motor itself. I believe they're pretty cheap and not too bad to replace.
98 Jeep Grand Cherokee 5.9 Limited / 96 Dodge Ram Indy Pace Truck / 87 Dodge Charger GLHS / 85 Dodge Omni GLH
Low idle, rough idle problem and more starquestbd22 4.7L PowerTech V8 Specific Topics 9 01-17-2012 04:03 AM
Not too loud, but bubbling. tastoffel Exhaust 4 08-02-2011 07:32 PM
Idle Speed Motor (AIS) problems code 25 jpmassa 5.9L V8 Specific Topics 3 06-05-2011 10:59 AM
Idle Speed Motor (AIS) problems code 25 jpmassa Electrical 2 06-02-2011 11:18 PM
Best Performance Exhaust zanegriffin 2010 Dodge Ram Forum 9 05-29-2011 10:42 AM
= Copyright a Network Site =Ad Management by RedTyger
