Old 08-06-2011, 12:08 AM
jbaidas81 jbaidas81 is offline
Vehicle: 2000 Dodge Ram
jbaidas81 is on a distinguished road
Question 2000 Ram Headlight Issues
I'm having headlight issues with my 2000 Dodge Ram. Shortly after I acquired the truck I noticed that my passenger headlight was dimmer than my drivers headlight. My first thought was that maybe the bulb was going bad so I pulled both of them out and checked them, they both appeared good upon completion of a visual inspection. I then swapped the bulbs, put the one from the passenger side into the drivers side and vice versa. The result was the same, the passenger headlight was still dimmer than the drivers side. I then noticed that the passenger headlight wires had been spliced previously, I proceeded by disconnecting the splices and reconnecting them in order to insure that all of the connections were good, the results were the same. I also noticed that my passenger side turn signal is dimmer than the drivers side. Also when I switch to my high beams, the drivers side switches over with no problems, but the passenger side bulb seems to dim when switched to high beam and even goes out momentarily. I've had a few people suggest a bad ground; however, I've been unable to trace the ground wires for the lights on that side of the truck. Any help would be greatly appreciated.
Old 08-08-2011, 12:01 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I'm not sure I have an answer - so how about a
Old 09-21-2011, 06:52 AM
DadzDodge DadzDodge is offline
Vehicle: 1996 Dodge Ram
Rep:37
DadzDodge is on a distinguished road
This is a long shot but how do the electrical connections look on the passenger side's bulb sockets? Maybe moisture has made its way into the light fixtures and caused some corrosion. You might try cleaning up the connections with light sandpaper and see if that helps. Like I said, it's a long shot but perhaps worth a try.
Old 10-03-2011, 03:26 AM
DODGECUMMINSWOODY DODGECUMMINSWOODY is offline
Vehicle: 2001 2500 4x4
DODGECUMMINSWOODY is on a distinguished road
Without looking at it I would say theres a 99% chance it is a bad ground to find ground look in front of the battery on the left side on the radiator support should be two wires on that stud
Old 10-09-2011, 09:00 AM
Okiespaniels's Avatar
Okiespaniels Okiespaniels is offline
Vehicle: 2000 Dodge 1500 QC 4x4
Trim Level: Fleet
Rep:47
Okiespaniels is on a distinguished road
On my 2000 there are two sets of ground wires on the left inner front fender attatched to studs. Thees connecttions can get corroded from road salt but also battery fumes.
I had to do a radiator swap and removed both looms and cleaned them. After reattaching them to the fender studs I painted them with liquid electrical tape to resist the corrosion.
Fuel Pump Issues 2000 1500 5.9l Hemiorange Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 1 05-23-2011 03:33 PM
Headlight Issues Dodgegirl1980 2009 Dodge Ram Forum 4 03-07-2011 08:16 PM
2000 ram sport -- front end issues!? jaredtowne 5.9L V8 Specific Topics 7 12-05-2010 08:03 PM
2001 ram headlight issues saintdog1 Newbie Checkin! 7 05-25-2010 03:37 PM
Headlight and tail light issues Honda125 Electrical 7 05-15-2010 07:44 PM
