Old 10-08-2011, 01:08 PM
Dodge1500's Avatar
Dodge1500 Dodge1500 is offline
Vehicle: 96 Dodge Ram 1500
Rep:32
Dodge1500 is on a distinguished road
Default Battery Draining
I have noticed in the past month since ive had the truck that maybe twice a week the battery will go dead on me, i had no problems with it when went on vacation (over 600km away it was fine for the week) but driving around the city to and from work (within 10km) i run into this problem a couple times a week. Usually i get home from work around 5ish and leave it overnight then the morning it doesnt want to start, i will sit in there for 5 minutes or so and then it will start (sometimes). I have taken it to a auto repair shop and they ran a draw test on it and said there was nothing. They replaced the battery with a bigger one and im still having the same problem. The truck has a compustar alarm, aftermarket LED taillights and it was wired for 8000hids until the ballast fell out. Its also wired for fog lights in the back. Its a 5.9L. The truck is a 96
Old 10-09-2011, 03:12 AM
sonocativo's Avatar
Color: Electric Blue
Rep:215
Sounds like an internal regulator in the altenator is shot, autozone can test it while in the car as well as battery andthe whole charging system with their roll out thingy. Some altenators drain the battery when the regulator goes as well as batteries do develop shorted cells either they be new/used or just old shelf life...
Mike
Old 10-09-2011, 06:51 AM
daggertats daggertats is offline
Vehicle: 2011 ram reg cab 4x4
Trim Level: st
Color: deep water blue pearl coat
Rep:14
daggertats is on a distinguished road
im not sure if all batteries are the same but ours at work(diehard) have a little round sticker on the side of it. its the date ...example 5/11 ....the battery is sellable for a yr after that then it is considered too old .
Old 10-09-2011, 01:36 PM
Dodge1500's Avatar
Rep:32
if an internal regulator in the alternator was shot wouldnt the stop it from charging the battery all together? When i went on vacation i drove my truck up to kamloops (roughly 600km away) and then my truck sat for the week while i was there and it started right up.........or could that just have to do with the fact the battery was only a week old at that point?
Old 10-09-2011, 01:42 PM
sonocativo's Avatar
Rep:215
Nope, there is a rectifier in it, and if it goes out the current can reverse and drain as if it is grounded. The rectifier only allows the current to travel in one direction, when it goes out the alt can still charge but it will also allow it to drain.
Mike
Old 10-09-2011, 01:57 PM
Dodge1500's Avatar
Rep:32
Good to know thank you very much
Old 10-11-2011, 06:31 PM
DODGECUMMINSWOODY DODGECUMMINSWOODY is offline
Vehicle: 2001 2500 4x4
DODGECUMMINSWOODY is on a distinguished road
I had a battery that had a bad cell it was an intermediate problem would do the same thing as your describing
Old 10-11-2011, 06:50 PM
sonocativo's Avatar
Rep:215
as stated in #2
Mike
Old 10-11-2011, 07:13 PM
Originally Posted by sonocativo View Post
as stated in #2
OK I saw that just passing on my past battery eexperiance
Old 10-11-2011, 07:58 PM
sonocativo's Avatar
Rep:215
No harm done, didnt mean for it to sound off... Just basically saying I mentioned that in post #2... My appology to you if it sounded defensive or anything....lol
Mike
Battery Drains when Truck is parked MMMMDude Electrical 28 12-17-2014 11:58 PM
Ram won't start after sitting a few days... Airdog 5.7L (345 cu in) HEMI V8 Specific Topics 67 04-22-2014 10:30 PM
cruise control dpaul272 Newbie Checkin! 17 08-02-2012 03:59 PM
Battery Isolation Unit? dfatt123 Dodge Ram General Discussion 2 05-17-2011 06:28 PM
Battery Won't Stay Charged! taycom Electrical 8 12-22-2010 09:15 AM
