Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 08-06-2011, 09:23 AM
06 BigHorn's Avatar
06 BigHorn 06 BigHorn is offline
Vehicle: 2012 Dodge Ram
Trim Level: Express Quad Cab
Color: Deep Cherry Red
Rep:153
06 BigHorn has a spectacular aura about06 BigHorn has a spectacular aura about
Default Seized strut bolt - HELP
I'm trying to replace my stock front struts & springs with some Monroe quick struts but the lower strut bolt is seized in the bushing. I tried pounding it out to the point the bolt is starting to mushroom. Tried using a puller & that didn't move the bolt either. The bolt does NOT turn.
If the bolt is seized this bad is the bushing destroyed? If I heat it, will that destroy the bushing? I can't find a replacement bushing online & other similar topics talked about having to replace the whole lower control arm.
I picked up some new bolts & nuts @ the dodge dealer yesterday, picking up new lower strut / lower control arm bushings today. Was hoping not to have to replace them!
If the lower control arm is not low or high enough, would that put enough pressure on that bolt that it wouldn't turn? I can only turn the bolt a little & the bushing turns with it. Only to return back when the wrench is released.
It's a truck, not a cream puff
Old 08-08-2011, 12:06 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Hi, I'm not sure I have an answer - so how about a
Old 08-10-2011, 02:25 AM
andrewdains's Avatar
andrewdains andrewdains is offline
Vehicle: 2006 Ram 1500
Trim Level: Big Horn SLT
Color: WHITE
andrewdains is on a distinguished road
Try some deep penetrating oil on the bolt. Also, a breaker bar and something to brace against, ie. concrete. The shocks should have come with a new bushing. I know the Rancho 9000xl I put on mine did.
Old 08-10-2011, 12:54 PM
AndyXplorer's Avatar
AndyXplorer AndyXplorer is offline
Vehicle: 2006 Dodge Ram 1500
Color: Blue
Rep:39
AndyXplorer is on a distinguished road
Ive done this twice, and each time the lower bolt was seized. The first time was to put the leveling kit in, i just eneded up cutting the bolt head off and pounding it out, The second time i instaled Ranco 9000ES struts, cause the factory monroe ones were seized, and i wasn't going to replace them with the same pieces of junk. I used Kroil, and worked it back and fourth with a 1/2" impact for about an hour, spraying it each time i went back and fourth, it won't move much for the first half hour, but eventually it comes out. The problem is there is a layer of crap buildup not allowing the bolt to come out, and since the strut grabs the bolt from each end, it actually bends the bolt in a u shape, you can't see it, but its just so ever bent. Either go to dodge and buy a new bolt, and cut the old one out, or use the Kroil method.
Old 08-10-2011, 01:00 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
^ impact comes in handy with this stuff, I replaced struts on another vehicle once and also worked the bolt with an impact for at least 30 minutes each bolt, with wd40 at the same time...I don't know that I could have done it without the impact...
Sean
Old 08-10-2011, 01:05 PM
Color: Blue
Rep:39
definatley snrusnak, there is definatley no way you are getting the bolt out without an impact. Not for the amount of work needed to be done
Old 08-10-2011, 01:08 PM
snrusnak's Avatar
Rep:1385
Yeah what I did was hold the trigger on the impact to loosen the bolt till I pretty much had no air pressure in my compressor (light duty compressor for nail guns, etc...) waited about 5 min for it to fill up, reverse the impact, go the other way with the bolt, then repeat...It'd take a week to get a bolt out by hand doing this...if you could physically do it lol. When I first started I didn't think the bolt was coming out at all the first few attempts, but it sort of got easier and easier the more I tried.
Sean
Old 08-11-2011, 06:32 PM
06 BigHorn's Avatar
Rep:153
I have new bolts, nuts & bushings. Anyone replace the whole bushing ?
I'm to work on it friday night!
Old 08-12-2011, 02:21 PM
Color: Blue
Rep:39
i didnt repalce the bushing, didnt need to, i'd imagine you have to take the whole control arm off and press it out, and press the new one in. If you are going to cut the bolt, you need to work it back and forth with an impact first to get it a little broken free, i had about 1/2" coming out before i cut it off, i think if you cut it flush from the get go you might be fighting it alittle, cut the stud side off and pound it out that way, I think the bushings might be a bigger pain in the ass than you think, maybee don't need them
Old 08-12-2011, 02:36 PM
Rep:2657
go to a gun shop & purchase a spray can of AERO KROIL it is sort of expensive as penetrating fluids go, but you really need it for jobs just like this
most times PB BLASTER is enough, but KROIL is for the really difficult jobs
if you can take the part completely off, then a press is the way to go
problems removing the lower strut bolt on 2006 1500 breck83 Suspension 9 04-18-2014 05:19 PM
HELP ! Lower strut bolt problems 06 BigHorn Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 1 08-08-2011 11:36 AM
Help! Bolt won't come out of A Pillar! jtownes14 Body & Interior 4 06-15-2011 01:51 PM
cant get bolt of strut rod sullivan Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 7 03-17-2011 04:19 PM
Bottom shock bolt!!!!!!!!!!! ggrif Suspension 4 11-04-2010 11:00 PM
