Sensor on my battery case? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - News Desk > MOPAR NATION - Dodge Ram Club Regional Chapters! > Dodge Ram Forum CANADA
Old 08-06-2011, 11:35 AM
bghoenow bghoenow is offline
Vehicle: 98 Ram 1500
Trim Level: basic
Color: green
bghoenow is on a distinguished road
Default Sensor on my battery case?
I changed my battery yesterday (98 Ram 1500). The vehicle does have a security system that I never use seeing as I live in a rural area. The security system is Audiovox AS9490-4P.
While I was changing the battery, I also cleaned out the bottom of the battery case. It was than that I noticed a removal plastic piece on the bottom of the case, about an inch-inch and a half in diameter with a wire attached. Question...is this part of the security system? Is it some sort of failsafe system in case the truck flips??
While on the subject...after I changed the battery, took a quick drive down to the dump (about 5 minutes). Upon restarting, the truck died as I put it into reverse and drove a couple of feet...completely...no lights, nothing. I could tell right away because I had no brake or steering assist. Threw it into neutral and it fired up again and drove home. Again, is this somehow related to the security system? Wish I could take it our but it looks like it could end up opening a whole other can of beans!
Any thoughts or ideas would be appreciated.
Thanks, Gord
Old 08-06-2011, 11:47 AM
RedRammer99 RedRammer99 is offline
Vehicle: 2006 Dodge Ram 3500
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
RedRammer99 is on a distinguished road
My guess that is a temp sensor for your battery. I believe with the diesels the charge at a higher rate on a cold battery.
Old 08-06-2011, 12:49 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
It's the BTS (Battery Temperature Sensor). It is used by the PCM to alter the charging system based on battery temperature. Removing it will throw codes and cause the MIL/CEL (Check Engine Light) to light.
brad
Interested in one of my mods?
Old 08-06-2011, 03:49 PM
Trim Level: basic
Color: green
Really...a BTS? Never knew that? It isn't a diesel, but it still makes sense. Thanks much. Any guesses at the "just dyin'" part? Or could I be making too much of a coincidence between a security system, a battery replacement and stallng out.
These security systems remind me about the time I thought I'd throw a remote starter and surprise my wife for Christmas. Than I read the instructions. Seriously...to go thru all that to install one, I just go start it for her come winter.
Thanks again! Gord
Old 08-06-2011, 03:59 PM
brad12kx's Avatar
Rep:2581
I think it's coincidence. Before putting any blame on the security system, I'd first look at everything around the battery replacement operation....
Thinking out loud....
Battery cables - Did you clean them really good before connecting to the new battery?
Are the battery cables real snug....no need to over tighten, but sometimes they appear tight by the wrench, but you can still twist them by hand. This is usually because they haven't been pushed down far enough of the tapered battery post.
Are there any other electrical connections in the vicinity of the battery that could have been partially dislodged or loosened in the battery changing process?
brad
Old 08-07-2011, 11:26 AM
Trim Level: basic
Color: green
Thanks Brad. Yup, all connections are tight and were cleaned to a sparkly shine before reconnecting. Did a 1/2 hour drive yesterday with no problems. I dunno, maybe the truck just had a little brain fart?
Battery Drains when Truck is parked MMMMDude Electrical 28 12-18-2014 12:58 AM
Ram won't start after sitting a few days... Airdog 5.7L (345 cu in) HEMI V8 Specific Topics 67 04-22-2014 10:30 PM
cruise control dpaul272 Newbie Checkin! 17 08-02-2012 03:59 PM
Battery Isolator WesGPS Electrical 2 04-02-2011 01:43 PM
Battery Won't Stay Charged! taycom Electrical 8 12-22-2010 10:15 AM
