Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 08-06-2011, 05:12 PM
Turbovsix's Avatar
Turbovsix Turbovsix is offline
Vehicle: 2010 Dodge Ram Crew Cab
Trim Level: SLT Big Horn
Rep:83
Turbovsix will become famous soon enough
Default Routing wires through the firewall - best place?
Hey guys -
I'm going to be wiring up some KC lights this weekend - haven't looked yet, but for those of you that have done something similar, where are you finding is the best place to route wires through the firewall?
Thanks in advance for the help -
Rich -
2010 Dodge Ram 1500 SLT Big Horn, Crew Cab HEMI - all stock!
2012 Jeep Grand Cherokee Limited
Old 08-06-2011, 05:26 PM
Rep:2616
I believe that you will find a couple rubber plugs in your firewall, some will have some wires going through them already & others will still be unused
i have not looked myself, but on the underside of the steering wheel columns dust boot, you may find a little nipple in the rubber, you could cut it just enough to pass wiring through.
Someone else will chime in with what they did on their Rams
Old 08-06-2011, 06:47 PM
Turbovsix's Avatar
Rep:83
Thanks GTyankee - also any advice on what wire to tie the power in for the KC wiring harness? Should I crimp on a connector and connect it to the TIPM?
Rich -
Old 08-06-2011, 06:50 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
I'm not sure about the 4th Gens, but on my truck near the brake and gas there is a plastic clutch plate and I just drilled a hole in it and put a rubber grommet on it. Works perfect for my power wire for my amp.
Dillon-aka, The Little Kid
Old 08-06-2011, 08:02 PM
Rep:2616
No matter where you run the wire, you will want the correct sized in line fuse & a ON/OFF switch, i use rocker type for my CB radio & another auxiliary fuel pump switch, my wiring goes directly to my battery
on my last truck i ran a mini fuse panel & it was powered through a Ford Starter Relay, a battery isolator should also work
Old 08-06-2011, 09:48 PM
Turbovsix's Avatar
Rep:83
Yeah, the KC Slimlight kit came with a complete pre-terminated wire harness with fuses, an on/off switch, relay, etc.
I figured out where I'm getting power from - I crimped on a terminal ring and am going to connect it to the + post on the fuse box....
Rich -
Who Makes AfterMarket Wires Silver04Ram Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 5 04-15-2011 10:06 PM
Wires through the firewall Stangshcky12 Custom Dodge Ram Interior and Exterior Lighting 7 04-03-2011 08:24 PM
Wire routing through firewall for fog lights ram1hemi Custom Dodge Ram Interior and Exterior Lighting 23 01-09-2011 08:08 PM
shorty plug wires HemiGTX 5.7L V8 Specific Topics 2 11-09-2010 04:02 PM
getting wires through firewall on 2010 RandyS Custom Dodge Ram Interior and Exterior Lighting 5 08-28-2010 01:35 AM
