Old 08-06-2011, 04:52 PM
MoparMadness08's Avatar
MoparMadness08 MoparMadness08 is offline
Vehicle: 2008 Dodge Ram
Color: Cool Vanilla
Rep:63
MoparMadness08 will become famous soon enough
Default Biltein shocks ?
Are these the shocks i need to level my truck? Just making sure since there are different ones.
Part Number: 25-187595
Setting: 5160 Remote Reservoir
Drive Type: 4WD
Position: Front
Descriptor: Front Lifted Height: 0-3"
*Collapsed Length (IN): 15.20
*Extended Length (IN): 25.96
*Collapsed Length (MM): 386.0
*Extended Length (MM): 659.5
Old Part Number: F4-BR5-G694-H0
Part Number: 24-185783
Setting: 5100 Series
Drive Type: 4WD
Position: Rear
Descriptor: Rear Lifted Height: 0-1"
*Collapsed Length (IN): 16.16
*Extended Length (IN): 26.14
*Collapsed Length (MM): 410.5
*Extended Length (MM): 664.0
Old Part Number: F4-BE5-6682-H7;F4-BE5-6682-H8
DSP 91 Oct Tune, BFI Intake, 14" Magnaflow, 180 Stat, Lund Genesis Tonneau cover, Recon LED light bar, Rocky Mtn ATS 305/55/20,
Old 08-07-2011, 12:51 AM
Color: Cool Vanilla
Rep:63
Really!!!! No one can tell me what shocks are the right ones?
Old 08-07-2011, 02:25 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Neither of those are what your looking for. I'm on my phone but I'll see if I can find the part number. You'll need the 5100 ride height adjustable shocks if that's how you want to level it or you'll need a front end lifted 0-3" shock if youchoose a spacer.
Old 08-07-2011, 02:31 PM
Color: Mineral Gray
Rep:177
46mm Monotube Shock Absorber (click for more info)
Part Number: 24-186988
Setting: 5100 Series Ride Height Adjustable
Drive Type: 4WD
Position: Front
Descriptor: Front Lifted Height: 0-2"
*Collapsed Length (IN): 15.18
*Extended Length (IN): 21.26
*Collapsed Length (MM): 385.5
*Extended Length (MM): 540.0
Old Part Number: F4-BE5-E523-H0
Should be it, assuming your truck is4wd. It'll be a different one if it's 2wd or if you just want a spacer
Old 08-07-2011, 04:14 PM
CJ.2007Ram's Avatar
CJ.2007Ram CJ.2007Ram is offline
Vehicle: 2007 Dodge Ram 1500 4x4 Q-cab
Trim Level: SLT Big Horn
Rep:28
CJ.2007Ram is on a distinguished road
They only make the 5160 for mega cab 1500s right now from what I saw.
Old 08-07-2011, 06:02 PM
Color: Cool Vanilla
Rep:63
I found them on ebay. Summit racing says they have 5 of them. But i keep hearing that everyone says they are on back order. What about the rear shocks. What part # are those? Yes mytruck is 4wd.
Old 08-07-2011, 06:31 PM
Color: Mineral Gray
Rep:177
Wait who has a mega cab? They dont make a ride height adj. Shock fir them cause they have a straight axle. I think they make a reg. 5100 shock for them though
Old 08-15-2011, 09:02 PM
Color: Cool Vanilla
Rep:63
ok will these shocks only go 2" for leveling. i need the 2.5" to level it.
Drive Type: 4WD
Position: Front
06 2500 CTD 4x4 Replacing shocks and have level kit. Which shocks? snowman44077 Suspension 4 05-02-2011 10:21 AM
5" Lifted shocks on 2" Leveling Kit!? pieece Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 04-06-2011 10:53 PM
Need Help with Shocks!!! jpaul51 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 6 12-05-2010 12:40 AM
How to install new Shocks with the wrong tools gregor413 Dodge Ram Knowledge Base 8 07-14-2010 08:34 PM
Suggestion on my new shocks? Silver05Ram Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 26 02-19-2010 06:41 PM
