Old 08-07-2011, 01:46 PM
blk11crew blk11crew is offline
Vehicle: 2011 4x4 Crew Cab 1500
Trim Level: SLT Big Horn
Rep:13
blk11crew is on a distinguished road
Default 2011 1500 lift and tires questions...
I'm looking at putting a lift and tires on my ram. i'd like to go with a 6" lift, and 38x15.5-18's. some questions i have are...
1. Will the 6" lift be enought to clear 38's?
2. Will the 38's fit under the bushwacker pocket styled flares? or will i have to go with the 37x12.5 to keep them under the flares?
3. Does anyone make a 6" lift that will also level the truck? I don't want to keep the factory rake when i go up.
4. What offset rim would I need to avoid rubbin using the 38's which are 15.5 wide, and the 37's which 12.5 wide.
5. Do any companies/sponsors on the board offer a package deal on rims/tires/lifts shipped to an APO address?
I know its a lot of questions, but just want to make sure i do this right. I'd like to do this only once. Thanks for any and all help. This board rocks!
Old 08-07-2011, 09:31 PM
Bordin's Avatar
Bordin Bordin is offline
Rep:516
Hey man, don't really have that much experience with that but I know RCX (Rough Country) makes a 6" lift which also levels out your ride.
http://www.roughcountry.com/suspensi...500-ram_6.html
37x12.50 is the recommended tire size.
Anyways just thought Id help you out a bit, other members should know a lot more
Justin
2011 Ram 1500 Lift cyrus19 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 15 07-31-2011 02:27 PM
2011 Ram Sport (4" Lift, 37" Tires) Bad Moon Bandit 2011 Dodge Ram Forum 41 07-20-2011 09:12 AM
2011 1500 SLT 4 X 4 Lift toothpick Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 31 05-12-2011 04:40 PM
Question on Lift and Tires alfredenewman Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 03-14-2011 09:49 PM
2010 Ram 1500 4X4 Lift Help! Cap10crch 2010 Dodge Ram Forum 6 03-02-2010 11:28 AM
