Old 08-07-2011, 03:03 PM
nightshifter nightshifter is offline
Vehicle: 2006 Night Runner (1500 Sport)
nightshifter is on a distinguished road
Default Coolant/Antifreeze for 2006 5.7L?
Is there a cheaper solution than buying from the stealership? What brand should I be looking for? How much should I buy to fill a 5.7L Hemi in a 4x4?
Didn't know coolant technology had come so far since I've last tinkered with things in that area.
Old 08-07-2011, 05:49 PM
Well, ya need a a little over 16 quarts to fill the cooling system.
The FSM calls for the MOPAR Antifreeze/Coolant (Formula # MS-9769) due to the aluminum in the engine. The MS-9769 is a ethylene glycol base coolant with organic corrosion inhibitors (called HOAT - Hybrid Organic Additive Technology). They recommend a 50/50 mix of Ethylene Glycol and distilled water.
Also, do not mix your existing MOPAR coolant with any other type. Mixing of coolants other than the specified non-HOAT or HOAT coolant may result in engine damage due to corrosion.
So, if you can find some HOAT, 100% ethylene glycol and distilled water, you can mix your own. Or, just bite the bullet and go with the MOPAR coolant. I figure the coolant is cheaper than rebuilding or replacing the engine down the road.
Old 08-07-2011, 07:34 PM
Wow, another of them dealer only deals. Bet they love that. My local dealer is real good at running up the prices too.
Where do you stand in the 1/4 chefred112 Drag Racing Discussion 162 08-16-2012 08:25 PM
For sale: 5.7l motor, bv heads, cam, etc etc DAYTONA81 Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 5 08-03-2011 02:45 AM
1/4 mile time srtsir Drag Racing Discussion 42 09-23-2010 08:27 PM
Differance Between the Ram 1500 R/T 5.7L vs Ram 1500 5.7L 345 RT Dodge Ram R/T 23 07-28-2010 09:02 PM
Dodge Ram K&N 1500 2500 3500 Ramrob Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 16 03-21-2010 12:50 PM
