trailer wiring - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 08-08-2011, 09:46 AM
chris0001's Avatar
chris0001 chris0001 is offline
Vehicle: 2007 Dodge Ram 1500
Trim Level: SLT QuadCab 4x4
Color: SILVER
chris0001 is on a distinguished road
Default trailer wiring
Not sure where to go....I have factory installed wiring, (bot 7 and 4 pin). Park, brake and right ok, but no left brake and signal. Read through other threads and checked fuses and ok. Checked wiring and where they conected the trailer wiring to the harness there is a white wire with a brown line sticking out...should this be the ground? Any help would be appreciated. Took a couple of pics....hope they attach ok. Can't really tell but the end of the white and brown wire looks to be capped?? Also, I could not find a ground wire in the area of the harness.
[/SIGPIC]
Old 08-08-2011, 10:42 AM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
I think brown is usually tail lights. What did you use as a diagnostic that your brake and turn weren't working? Did you hook up the trailer and it didn't work? If so, check your trailer wiring, I would suspect it over your truck. If you used a test plug, make sure all your contact on your truck are clean, and try again. If you have access to a multi-meter, use it to see if you are getting voltage in the plug first, and then if not, in the wire. If you have power to the wire, then there is a connection issue at the plug. If not, then you will have to trace the wire to find where the short/break is and fix it. This will work on the trailer too. If you plug is good on the truck, hook up the trailer and trace the wires to find where the circuit is broken.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 08-08-2011, 11:01 AM
chris0001's Avatar
Color: SILVER
used trailer wire test plug. I suspect I may have to trace where the 7 and 4 pin conect to the harness as the left turn and brake do not work on either. The big question is could the white wire,(with brown stripe), be a ground not attached?
[/SIGPIC]
Old 08-08-2011, 04:03 PM
Wildcat's Avatar
Rep:166
If your ground wasn't connected, none of the lights would work.
Old 08-08-2011, 04:40 PM
Rep:2929
There is a website that covers wiring diagrams from 2004 - 2009,
it is under Dodge body builders
http://www.dodge.com/bodybuilder/year.pdf
OR
https://www.ramtrucks.com//hostb/crossbrand/owners/en/
just click on your year & follow the prompts for 2007
http://www.dodge.com/bodybuilder/200...d/drquadmo.pdf
http://www.dodge.com/bodybuilder/200.../dr/drwdmo.pdf
trailer wiring MONT.RAM Electrical 4 11-11-2013 12:29 PM
Need Help With trailer wiring JoAnne N Electrical 7 05-15-2011 12:07 AM
Dodge ram trailer wiring issue sullivan LD RAM - General Discussion 13 03-09-2011 12:41 PM
Check trailer brake wiring warning lwalston Electrical 1 01-26-2011 07:21 PM
Make a wiring adapter to convert 4 pin trailer lights to 7?? kdanderson5 LD RAM - General Discussion 3 12-28-2010 02:40 PM
