Old 09-06-2011, 07:47 PM
MADDOG MADDOG is offline
Rep:22
It is too that good of an install.
The weather is beautiful and a bit HOT out here this week.
Old 09-07-2011, 12:41 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
And if you swing slightly north on the way, I'm about 1/2 way.
brad
Interested in one of my mods?
Old 09-08-2011, 02:38 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Continued some of the sound deadening this morning:
Also had some goodies arrive last night. I went ahead and started swapping parts over from the old carrier plate to the new. Just a few more things I need to address before putting the new pieces in the door. Went ahead and applied some deadener where I remember being trouble spots. Will add more once it's all together if needed.
Old 09-08-2011, 02:42 PM
chithead's Avatar
Rep:2078
Thought I'd show everyone how I got the new speaker wires into the front door. First, you have to remove the plug. Quite easy, just pinch the top and bottom on the front and back of the plug going into the door. It will then pop out, and you can unplug the harness. This reveals a very nice sized opening to run your wires through:
But... to make it MUCH easier. I removed the plug from the door. Not difficult at all, you have to remove two screws on the door side though. They are located here:
Not an easy gap to get a screwdriver into, is it? Out come the vise grips and the screwhead!
Ok now that's out of the way, pop this piece off:
And run the wire straight through. Then reattach:
And we have new speaker wires:
Old 09-08-2011, 02:47 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
What's the reason for a new carrier plate on the door? JW as I've not even seen the stock one...is it lighter or something?
Sean
Old 09-08-2011, 04:27 PM
chithead's Avatar
Rep:2078
It was due to modifications I made to the original one from a previous install. Best to just replace and start fresh.
Old 09-08-2011, 04:33 PM
Rep:22
In Other Words ^^^^ He hacked it up during the first install. ^^^^
Looks great, Daniel!
Old 09-08-2011, 04:50 PM
snrusnak's Avatar
Rep:1385
lol, I figured that out haha
Sean
Old 09-08-2011, 04:54 PM
chithead's Avatar
Rep:2078
Ah yes, the Layman's version ^^^
Ok the real reason is... I let Mayhem jump rope inside the door.
Rep:22
LMAO!!!
That Mayhem, always causing trouble.
